HELP! Camaro SS and z28 rims
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
I have a 99 camaro ss with the zr1 rims on them. They use 275/40/17 all around and wanted to just get the z28 rims that are 16" as they are cheaper to replace tires for. I bought the z28 rims with tires and the problem is they do not fit because the caliper is pretty big. Any suggestions?
I am not sure. The guy I bought it from says it was all stock so I am assuming they are. How can I tell if they're aftermarket? part number Im assuming?
Because I am broke 19 year old college student that refused to get a I4 camry! lol I am planning on building it up after college.
Does it need tires right now? If the tires are in decent shape and you drive somewhat normally they should last quite a while. It pays to shop around though, I always buy from Tirerack but came across a set of 275/40's for 83 bucks a piece locally.
