Nitto 555R questions inside
Old Mar 10, 2004 | 03:00 PM
darrensls1formula's Avatar
Default Nitto 555R questions inside
My car is in Sig and I got a TCI SSF3500 coming very soon. I know I can't get traction on street tires so I'm switching to Nitto 555R Drag Radials. The problem is I can not afford new rims right this second after dishing out 1K for the converter, shift kit, tranny cooler and install (I don't have the tools or knowledge to do tranny work myself). So for now I'm gonna run 245 Nittos since they fit my stock rims.
I have read that to get any real traction after this hard hitting converter goes in I need to upgrade to 315 Nittos. So what I need to know is,
What size rims hold the 315 Nittos?
Where is the best place to buy those rims for a good price?
Will the new rims look ok with stock ones still up front?
Thanks in advance.
Old Mar 10, 2004 | 03:24 PM
heyitsTaJay's Avatar
Thanks in advance.
315's would probably be for 11inches wide
check our sponsors for rims, and ebay & ebaymotors. also check the the "for sale" section here
well depending what wheels you have.....you might be able to keep stockers upfront and put new 17x11's outback. But with that size tire you probably will be rolling in the fender because of fitment issues.
hope this helps
J
Old Mar 10, 2004 | 10:50 PM
Wesley SS's Avatar
You dont need 315's to hook with that convertor a few people run PT4400's on 275 drag radials and they hook, just heat them up. For 275's you need a 9" wide rim and for 315's you need a 10.5" rim.
Old Mar 10, 2004 | 11:03 PM
JCurtin's Avatar
I have 275 nitto drags on the rears of my 17x10 smoothies. And yes they hook up way better than the generic tires i had on before. I nailed the gas from a dead stop and destroyed my rear tires. That was the 1st time I nailed it from a stop with the tci 3500. Nittos went on the next day!
Old Mar 11, 2004 | 05:53 PM
Todd@AZPowerAndSound's Avatar
on my old vig 3200 i went 1.52s on my 275-40-17 nittos. Ive seen mid 1.5s on 245 nittos as well on a godo prepped track and major tire heating
Old Mar 12, 2004 | 07:37 AM
That sounds good. What size rims do I need for the 275 Nittos? I might go that route. Thanks for all the responses here guys. I appreciate it.
Old Mar 12, 2004 | 09:19 AM
9 or 9.5" is ideal
Old Mar 12, 2004 | 09:53 PM
JCurtin's Avatar
so i shouldnt run 275s on my boyds? why doesnt nitto make a 285 drag radial!!!
Old Mar 13, 2004 | 12:17 AM
Myth01's Avatar
I'm new to the site, but my question is which nitto drag radial is the best for mostly street some strip, and will fit 18"x9.5" rims ( looking for c5 rims), i know 555's up in front, but which in the rear?
Old Mar 13, 2004 | 01:07 PM
no..275s are fine on the 17x10, I was just showing ideal. And Nitto DOES make a 285 drag, but its 18" hehe
So Myth01...go with the 285-35-18 new Nitto Drag Radial.
Old Mar 13, 2004 | 01:12 PM
1 SIC Z's Avatar
could you send me some pics of your car to kwik02z@yahoo.com
I want to see how the 275/40/17 tires look on the Smoothie II 10" rims....thanks
John
Old Mar 19, 2004 | 06:59 PM
M6HuggerSS's Avatar
is there a big diff between g-force kdw and nitto dr
