Should I with 315 or 335 for rear.
So, are the 44mm offset recommended for a better fit? Or are the 38mm offset preferred? Not sure, but the 44mm will sit deeper inside, right, or is it the other way around? Gonna get mine black, then send them out to my local powdercoater to finish them off done entirely in black.
Stock height, widened 2000 WS.6 wheels. I did do some BFH towards the front to clear the tires and plan to cut out the bumpstops for more room. Not sure if the fenders need to be rolled, but probably wouldnt hurt. Mine were pretty banged up from the 275/40-18s that came on the car when I bought it.
