17" MT ET Streets..what tube size???
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
I'm running the MT ET Streets and after getting a flat tire yesterday I need to remount the tires with tubes according to the people that fixed my flat(these tires are suppose to be tubed...but most folks are going without).
I cannot seem to find any that fits the MT 17". Any recommendations...Jegs sells the tire but no tubes that fit???
Size: 26 x 11.5-17LT
Rim: 9''
Tread: 10''
Section: 11.5''
Diameter: 26''
Thanks,
Ron
Rim: 9''
Tread: 10''
Section: 11.5''
Diameter: 26''
Thanks,
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
Ron
Originally Posted by Ed LS1 Vert
I run them and according to MT, they don't require tubes.
![Bulls#!t](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_bs.gif)
Still a great tire just need the tube
![The Patriot !!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_patriot.gif)
Rim: 9''
Tread: 10''
Section: 11.5''
Diameter: 26''
Thanks,
Ron
Rim: 9''
Tread: 10''
Section: 11.5''
Diameter: 26''
Thanks,
Ron
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by msavel01ss
I thought these things we not released yet
. Have you had them to the track yet, and if so how did they perform?
I normally run 8.2 - 8.6 depending on my 60' which is usually 2.2 - 2.4
1st run @ 20 psi, lousy burnout. 8.6 @ 2.2
Next runs @ 16 psi, lousy burnout. 8.0 @ 2.0
Tried it with some water @ 16 psi. Nice smokey burnout. 7.5 @ 1.8
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
I tried them for the first time at my local 1/8 track.
Tried it with some water @ 16 psi. Nice smokey burnout. 7.5 @ 1.8![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Originally Posted by stephenz99z
hey i just picked up the 26x11.50 16LT MT et streets where do i get the tubes for them
