need help with offset!
what offset would i need to flush my wheels with the fenders? im going to run ccw classics and want them to sit perfect with the wheel wells and fenders. i would really appreciate any feedback! ive read 50mm offset should do it but i need to know forsure and would that be 50mm offset positive or negative?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
i had called them to get a quote on pricing ect. and they said i needed to tell them the offset i wanted. they were kind of rude actually, not only that spending 2900 for a set of new wheels to get them and them be wrong based off of someones opinion that it should be flush would suck lol im sure someone on here has a set or has a set of wheels that are flush. i appreciate you responding though
what offset would i need to flush my wheels with the fenders? im going to run ccw classics and want them to sit perfect with the wheel wells and fenders. i would really appreciate any feedback! ive read 50mm offset should do it but i need to know forsure and would that be 50mm offset positive or negative?![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
im going to do 11in rear width and 10in front. with a 4.5in lip in the rear with 3.5in up front and just need to figure out back spacing and offset to make sure they sit flush.
i may go 12 but dont know if i will have fitment issues or not. so any feedback on that would be appreciated as well. i would like to run a 335 with no rubbing idk if that possible
If my math is right a 38mm will get you to the fender in the front.
Lee is absolutely right. Look at the pic below. Ive done the math and the outer edge of my rear wheels sits (give or take a mm) exactly where a 11" wide wheel with a 45mm offset would. I wouldnt go any wider than a 315 tire simply because anything wider would hit the quarters on big bumps. If you absolutely have to have a 335 tire, bump the offset up to 50 or 52mm
My fronts are 38mm but only 8.5" wide... So imagine them sticking out 1.25" out further and they'll be damn-near flush without sticking past the fender
![](http://i1197.photobucket.com/albums/aa423/vmohed/2012-05-01172037.jpg)
