335/35/17s on stock height.
#41
OP, give it up, they don't fit, they won't fit. The reason you have 2 1/2" inside is because you have that much outside
![Twak](https://ls1tech.com/forums/images/smilies2/twak.gif)
#43
This subject was beaten to death ten years ago. PO must have ridden the short bus. Everyone has told him the facts and he still doesn't understand. Dude even if they were free mismatched tires and wheels with the wrong offset will always look like crap. Sell them and start over. Nuff said.
#44
Because 335's barely fit in the wheel well of these cars and when they do you have to hammer the sh*t out of the car to prevent rubbing.
The only reason you have backspacing is because the tire shop either used spacers or your offset is way off which also brings your center out too far and can become dangerous, especially with non-hubcentric wheels.
Sorry you are on a budget man... but doing all the research first would have ended up saving you money in the long run. If you want to keep the tires, you now need new wheels.
