Rim and Tire Combo Help Needed
Currently they have 245/40z/18 sized tires on them and i need new tires all around. I definitely want to step up the size of the tire, they have an 8inch back space so i think i can fit a 295/40z/18, in the rear and a 255 up front. However im not sure i like the look of the rim i mean they are okay, i also have a set of c5 rims that need to be re chromed and also need tires. What do you guys think would look better? And What size tire do you recommend for front and back? Also anyone have pictures of NBM trans am with vette rims?
Thanks!
I personally think 18" is too much. I see people with these 22" rims, and I think it's tacky. I like the 17's on my WS6, my tires are 275/40/17. This is about as much as is acceptable to me.
Think about the diameter change, how it affects your speedometer, acceleration, etc?
i'm running a deep dish vette rim fro OE wheels...c6 i think.
255/17 on the front and 295/18 on the rear.
i think they look great and fills up the wheel well really nice. i also did the heater hose mod to drop & level the rear a bit, which helped.
to make the rear a little more flush with the fender, i also have a spacer. It's not needed, but i liked the look of them out a little more. i also had to do a little grinding, but it was minor and totally worth it.
the overall height is very close to stock and i didn't have to change the speedometer. i have the hypertech tuner which would allow me to, but they were close enough to leave it be.
There's a sticky: https://ls1tech.com/forums/wheels-ti...must-read.html
