275/60/15 BFG dr's
Old Apr 7, 2004 | 11:41 AM
M6HTZ's Avatar
Default 275/60/15 BFG dr's
I just picked up a set of used prostars with this tire (275/60/15) mounted on them. They look like they will a tight fit. Anyone run these tires?
Will they throw a ABS code because they are 28 inches tall?
How do the hook compared to 275/50/15's?
Thanks for the info...
Old Apr 7, 2004 | 12:09 PM
gator's 99TA's Avatar
the 60 series is a 28" tire versus your 26" tire on a 50 series. it will require some clearancing on the wheel well. only way to tell is to run it. lots of guys run a 28" tire. i know they hook damn hard compared to the 26" version. looks like a slick!
Old Apr 7, 2004 | 01:29 PM
M6HTZ's Avatar
I need to get rid of the 10 bolt before I strap them on. I looks like the 9 inch is going to be necessary if they hook that hard.
I just can't believe how big they look.
Old Apr 7, 2004 | 01:47 PM
it is big.
Old Apr 7, 2004 | 04:36 PM
black_z's Avatar
I am getting a set of these for $15. They are almost bald. I better be damn careful on my stock 10 bolt.
Old Apr 7, 2004 | 05:06 PM
SPANKY LS1's Avatar
I ran a 275/60/15 Nitto for a little while on 15x8 Pro Stars. They fit fine, just had to roll the fender lip. Yes, the ABS light will be on. Below are a couple of pics of them on my 2002.
Attached Thumbnails 275/60/15 BFG dr's-back-corner.jpg   275/60/15 BFG dr's-side-1.jpg
Old Apr 8, 2004 | 12:40 PM
Damage Inc.'s Avatar
Sweet Cheeks
How hard was it to grind the calipers enough to fit the Prostars? I really want the look, but am afraid of the grinding.
Old Apr 8, 2004 | 01:07 PM
M6HTZ's Avatar
How do you roll the fender lip? Your car looks sweet with the prostars!
Old Apr 8, 2004 | 01:12 PM
is it me or are the big tires sticking out beyond the fender? maybe it is just the angle?
Old Apr 8, 2004 | 06:28 PM
SPANKY LS1's Avatar
Its just the angle, they did not stick out at all. I rolled the lip with a towel wrapped hammer.
