Billet Specialty Street lite thread *DON'T QUOTE PICS!!!*
My rear is narrowed 3" on each side I have adjustable phb and offset control arms. It's an 02 transam and I'm hoping I can fit those tires and not have to bfh to much to fit the same wheel/tire setup
Just curious when you guys put the 15x4 up front what back spacing do you get? I have the 15x10 in the rear that's f-body specific and I'm looking at getting the fronts soon but can't find anything saying they will for sure fit. .
Thanks
Billet Specialties Street Lites. 15x4 in the front and 15x10 with 4.5 backspacing in the rear. Midwest Chassis Fab Nine rearend narrowed 3 inches per side. Car is currently apart for a turbo build.
[QUOTE=MYSTIC-1SC;18941119]Billet Specialties Street Lites. 15x4 in the front and 15x10 with 4.5 backspacing in the rear. Midwest Chassis Fab Nine rearend narrowed 3 inches per side. Car is currently apart for a turbo build.
Thanks
I got 15x4s & gotta use a 5/16 spacer & the outside brake pads cant be new or caliper touches the wheel. Slightly worn outer pad works. Don't think they make a 15 inch front runner that clears stock calipers. At least not Billet Specialties. IIRC its a 1.75 backspace.
hi guys really interested in these wheels I am getting the f bod specific rears and want the 15x4 fronts what offset do I need has factory brakes I also want to keep the wheel inboard and not stick out past the front fender
Not gonna happen with a 15, get 17 inch fronts if you want that.
