15x5 racestar dragstar fit perfect.
I posted awhile back and couldn't get no replies.So I bit the bullet and went ahead and bought some.So just for future reference the 15x5 fit perfect with no grinding when I get my tires mounted I will get some pics up.Backspace is 2.375. These are unilug so direct drill would be even better.
Hey thanks for being the guineapig on this. It's great to know that we're not stuck with 3.5"s up front and can run a little more stable tire up front for street duty. They look great. How fresh are your brake pads and how much gap is there from the caliper to the barrel? Also what size tires are you running on them?
Yeah maybe when I throw the 185 on they wont look as low. I got 32lbs in them know how much air can I put in them on the safe side? 165 80 nexens.What is the biggest tire I can run on a 5 inch rim?
http://www.teambeefcakeracing.com/92-550344p.html just make sure you get the big centered washers.I did not like the washers they sent me they were small. So got my washers from http://www.mccormackracing.com/ get your back rims from here front rims from beefcake.Racestar told me they were 2.375 backspace.Racestar said they dont make a 2.5bs.On the beefcake racing website says 2.50bs.
car is dirty i know.15x5 front15x8 with nitto 555r 275 50 on back.I like these tires on 8 inch rims you can bag the crap out of em.Alot of sidewall on a 8 inch rim.Glad i didnt get the 10 inch rims.
how did you like the 165/80/15 tires in the front? Is it a good size for the 15x5 racestar wheel?
