BFH mod?
Old Apr 13, 2004 | 10:48 PM
01 Red WS6's Avatar
Default BFH mod?
I just got my TT2 today. Im running 17X11s with 315s on the back. I didnt do the BFH mod, I just removed the bump stops. Worked out ok for now but I was curious if I would still need to do it. I dont have much clearance between the tire and the fender well. I have maybe 1/4 - 1/2 inch of space between them. I was thinking of just cutting the bump stop and trying to reinstall it, or maybe just leaving it off.
any suggestions would be great.
Also if I need to do the BFH mod would I leave the bump stop on while beating the hump or pull it off ( pretty much how do I do the mod)
Thanks for all your help
Old Apr 14, 2004 | 01:39 AM
onyxxtreme's Avatar
do a search in the appearance section
I remember a thread about good year or 2 ago, with a detailed how-to on some guys' SS
I had the page bookmarked, but its on my other computer
Old Apr 14, 2004 | 01:46 AM
tuffluck's Avatar
i don't think it's gravely important that the bump stop be on there. i do think the BFH would have been a wiser first option though.
Old Apr 14, 2004 | 10:41 PM
01 Red WS6's Avatar
Well I could put the bump stops back on. They just unbolted and I have them in the garauge.
Old Apr 14, 2004 | 10:46 PM
SUX2BU's Avatar
what the hell is BFH?
Old Apr 15, 2004 | 01:31 AM
derekdpt's Avatar
A good guess would be Big F*ckin Hammer.
Old Apr 15, 2004 | 11:00 AM
Xsta Z 28's Avatar
Do Not Take The Bump Stops Off!
Old Apr 15, 2004 | 05:05 PM
01 Red WS6's Avatar
Why not remove the bump stops?
Old Apr 15, 2004 | 06:44 PM
joeformula's Avatar
It keeps the rear end from bottoming out. You might need to shave off about 1/4 inch on the bumper stopper and the aluminum plate.
Old Apr 15, 2004 | 08:22 PM
01 Red WS6's Avatar
Hey how can I shave it off? I know I can cut the bump stop but what about the plate?
Also Ive done some searching, Can I just jack up the car by the axle and just reinstall the bumpstops? Will it rub when it is on the ground. I know it would wedge the bumpstop against the wheel if I jack up the car by the frame.
Old Apr 16, 2004 | 08:43 AM
Xsta Z 28's Avatar
The ONLY time the wheel/tire is going to rub the bumpstop is when the axle is at FULL Drop. So there are only two conditions:
1: When you raise the vehicle other than by the rear axle.
2: When you wanna play Dukes of Hazzard . . . .
EVERY car that I've had with big wheels and tires I have NEVER touched the bump stop, and have had no issues . . . .
Old Apr 16, 2004 | 09:31 PM
01 Red WS6's Avatar
Ok well Ill try to jack up the car by the axle and put the bump stops back on. Ill do it tomarrow and post the results. Thank to everyone for all the help
Old Apr 18, 2004 | 12:14 AM
01 Red WS6's Avatar
Well I did the BFH mod today and put the bumpstops back on. I did have to grind down a spot where the bump stop mounts but that was all. I also painted the back calapers. It all turned out really good. Thanks to all of you
Old Apr 19, 2004 | 06:19 PM
joeformula's Avatar
Did you shave off part of the aluminum plate too?
Old Apr 19, 2004 | 09:52 PM
01 Red WS6's Avatar
Yeah just a tad, I just rounded off the edge mostly
