Anyone running 275/40/18 on front?
what are you running on the back? 275/40 on a 18 is kind of tall.. specially if you are running a 295 35 in rear the fronts would be taller.. not by much but the would have more sidewall
Thinking of running 305/35/18. Reason I ask is because I'm buying 2 rims with tires already on them. And the rims are 9.5" wide and have 275/40/18 already on them. I bought 2 other rims 10.5" wide. Off ebay for the back.
I'm running 275/40/18's all the way around on my Trans Am. I forgot the offset of my wheels, but I *think* they are 35mm.
![](http://i112.photobucket.com/albums/n184/Tbird232ci/Trans%20Am/100_1337.jpg)
![](http://i112.photobucket.com/albums/n184/Tbird232ci/Trans%20Am/100_1340.jpg)
![](http://i112.photobucket.com/albums/n184/Tbird232ci/Trans%20Am/100_1342.jpg)
Pardon the dirty car.
There is some minor rubbing at full lock in the inside wheel well. I don't know if you will have the same problem, or have it worse with your offset compared to mine. My wheels are pushed out nearly flush with the fenders.
