Who has steamrollers on there firebird/TA or camaro?
looking for some 315 tires for a 98 formula firebird ws6
i dont know what all you have to do to get them to fit/ do i need to get wider rims? anyone have some nice rim/tire combo forsale they arnt using? some nice pic? how they mounted?
Are you looking to put 315s ALL AROUND, and not the 'staggered' setup soooo common/popular on here??
If so, go over to frrax.com, since everyone autocrossing in E/SP class, and those allowed by the rules to run 17" diameter wheels in road racing are ALL running that setup on their rides, on ALL corners.
My buddy had 315's on all 4 with 17 x 11 TT2's. Overly common wheel, but it worked really well. His car felt like it was on rails.
What are the BS OS recommendations for rear 315's on 10.5 or 11's?
My daily driver has NT-05 315's all around with ZR1 11x17 50mm replicas. I have 1/4" 6061-T6 hub centric spacers F&R. Rear also has BFH mod and tubular control arms. That works OK for V710's and A6's because the outer shoulder is rounded.
For street tires with square shoulders, it needs a bit more on the FR as on hard left lock it barely rubs against the sway bar arm. Rear also needs fenders rolled due to shoulders.
I'm swapping front hubs 1-2x per year, getting about 1.5-2 years per set of tires at < 1000 miles per month. Getting about 10-12MPG in the city but not trying for fuel economy. Tramlines badly on poor pavement and hard to get the tires hot compared to a narrower tire. But damn it's fun
btw thanks for the pic of that fender rolling tool always wanted to see it in action, makes sense now
Tire Smoking Tranny Blowing Director
For the rears had to remove the bump stop and beat the hell out of the inside fender well.
Fronts when it turns was rubbing on the bottom of the wheel well so my shop fabbed it up so the well turned in on the bottom so it doesn't hit. Can get pics if you want when it's out of the shop for exhaust install
I run 4 17 x 10.5 TTMs with 315s for autocross and track days.
The rear needed a little BFH mods and I wanted to keep the bump stops so I moved them in board a little. Plus I rolled the fenders. On the front I added a couple screws to the plastic inners fenders to hold them out better and off the tires.
Nice work as usual Dale!
