What aire pressure should I run?
Old 05-09-2013, 11:27 AM
black ttop's Avatar
Default What aire pressure should I run?
Bought some new used wheels and tires 16x8 OE chrome 5 spokes,
The tires look good. They are 245 50 16 Hankook Ventus HRIIs. They say max PSI of 44. I read that usually you want to run about 90% of max PSI.
What PSI should I run them at?
Street use. Spirited driving. Stock F41 suspension except for 32mm front and 19 mm rear sway bars with energy suspenson bushings.
Thanks!
Old 05-09-2013, 04:05 PM
leadfoot4's Avatar
I suggest 32 PSI.....
Old 05-09-2013, 04:09 PM
SSCamaro99_3's Avatar
I run 32 front 30 rear for the most part.
Old 05-09-2013, 09:00 PM
black ttop's Avatar
so 40 is way too much?
Old 05-09-2013, 09:11 PM
LILWS6's Avatar
Usually a good starting point is what the vehicle manufacturer recomends. Try looking in the drivers door jamb. I think i'm running 30 all the way around or 32ish
Old 05-10-2013, 06:40 AM
leadfoot4's Avatar
Absolutely!
Old 05-10-2013, 04:07 PM
I had some yahoos put new tires on a different car. They had 45 psi in them. Felt like I was going to launch off the highway.
Old 05-10-2013, 05:59 PM
black ttop's Avatar
lowered to 32 and it seems great. yes 40 was almost scary...
Old 05-10-2013, 06:11 PM
Furious1's Avatar
I'm running 30 all around, primarily in preparation for warmer weather...colder temps I run 32.
Quick Reply: What aire pressure should I run?
