285/35/18 on 18x9.5 wheel??
Old Apr 25, 2004 | 02:41 PM
Sniper33's Avatar
Default 285/35/18 on 18x9.5 wheel??
Just wondering if they will fit that wheel?? I have 275/35 now and they fit like a glove.
Old Apr 25, 2004 | 11:29 PM
jd13's Avatar
Should fit with no problem.
Old Apr 26, 2004 | 03:24 AM
Sniper33's Avatar
Thanks!! Just wanted to make sure.
Old Apr 26, 2004 | 05:52 AM
BoneSS's Avatar
I have them on my Y2K's, fit and look great.
Old Apr 26, 2004 | 08:33 AM
Xsta Z 28's Avatar
They'll fit, but will be a bit taller than what you already have.
Old Apr 26, 2004 | 05:04 PM
Ravenous T\A's Avatar
I got 295's, use the sig for pics
Old Apr 26, 2004 | 08:12 PM
Griswold's Avatar
Ravenous,
do you have any rubbing problems in the back with the 295's and the pro kit?
Old Apr 27, 2004 | 12:07 AM
BLASTER's Avatar
Ravenous, you fit the 295 on a 9.5" rim? That's not a 10.5 right? Just making sure.
Old Apr 27, 2004 | 05:25 PM
Sniper33's Avatar
Blaster I didn't forget about you and the duals. Just waiting on SSPhil to get done with his tranny and me to get my new rear. I'll keep you posted!
Old Apr 30, 2004 | 02:19 PM
1BadMoFo's Avatar
I just put the 285/35/18 GSD3's on my camaro, and I've got quite a few rubbing issues on the front. The rims are Cragar SS with +36mm offset. The tire actually rubs the part of the bumper cover that wraps around the car into the wheel well, so when I turn the wheels, it pushes the bumper cover out...not good. I think I'll be able to work through it, but no luck so far and I've tried a couple ideas already. I just can't believe it made such a different, they are only .19" taller, and .39" wider...gotta be the offset!
Old Apr 30, 2004 | 03:25 PM
Sniper33's Avatar
I'm not really concerned about the fronts, but good info for others. I'll just be putting the 285/35/18 Nitto 555R's on the rear and keeping the 275/35/18 Nitto 555's on the front.
Old Apr 30, 2004 | 04:26 PM
ratio411's Avatar
You can 'freak out' your ABS and TCS by using tires of different heights. Width doesn't matter, but some of your car's systems work off of sensors that measure wheel revolutions, if all 4 aren't in sync, it throws codes and lights.
The height difference you are talking isn't much, so someone else will have to jump in and say if it is enough to mess you up.
You will also throw your speedo out slightly.
Good luck
Just a heads up
Dave
Old Apr 30, 2004 | 08:51 PM
1BadMoFo's Avatar
I'm not sure about the sensors mentioned above, but if you are only putting 285's on the rear, then you'll be golden from the standpoint of rubbing or not.
Old Mar 12, 2018 | 06:27 PM
Robert Darden's Avatar
do you have any pictures of that set up on the front because right now I have 275/35/18, and I was thinking about going with the 285's
Old Mar 13, 2018 | 08:03 AM
No Juice's Avatar
You will be fine, here is a 295 on a 9.5 rears
Old Mar 14, 2018 | 10:35 AM
dojob's Avatar
285/35/18 +38 squared, no rubbing issues. Firebirds have even wider fender/qtrs too
Attachment 717416
Attachment 717417
