Brand New TTMs, Just Can't Roll...
Old 06-11-2013, 10:34 AM
apicia's Avatar
Default Brand New TTMs, Just Can't Roll...
I read that the unique offset of Torque Thrust Ms allow you to install the 17x9 and 17x10.5 combo (275/315) without any modifications at stock ride height.
I bought the TTMs in black with a polished lip. I also picked up some Nitto 555s (275/315). I had the wheels and tires mounted (using black wheel weights) and they went on the SS easily. No BFH. No rubbing. Perfect fitment.
Problem, you have to roll your rear fenders if you want to lower the SS and run the 315s. I am not willing to bang my car with a big hammer or roll my fenders. The car has only 11k miles. I might as well just put the stockers back on at this point.
Just can't bring myself to have the fenders rolled. I am now selling these wheels and tires. Lesson learned? Research before you buy!
Old 06-11-2013, 10:44 AM
ramairetransam's Avatar
rent a fender roller . bam done .
Old 06-11-2013, 11:42 AM
thunderstruck507's Avatar
What he said.
It's an F Body not a Hemi Cuda Convertible...no one is ever going to give a **** if the fenders are rolled whether it has 11k miles or 211k miles.
Old 06-11-2013, 12:31 PM
Revcore66's Avatar
I can understand what the guy is saying. If I had a 11000 mile car with mint original paint, I would shlt my pants if the paint cracked or the quarter panel rippled at all. Like he said, should have researched more first.
Old 06-11-2013, 01:30 PM
apicia's Avatar
I don't mind changing the springs and shocks, as those are just bolt ons. I was told by local guys that do roll fenders that the paint will likely crack.
I will sell these brand new wheels and tires (that should be fun) and get 9.5" wheels and avoid the rolling of fenders. I understand the previous comments, its not some expensive collector car, but the paint is so nice as it is.
Thanks for your responses guys.
Old 06-12-2013, 02:38 AM
willy9's Avatar
How much?
Old 06-12-2013, 03:17 AM
Blackbird-WS6's Avatar
I fit my tt2s 11inch rims with 315 tire on my ta. Im lowered and didnt bfh or fender rolling.
Old 06-12-2013, 03:52 AM
lemons12's Avatar
My 315 nittos on 17" TTIIs with BMR springs don't even come close to rubbing.
And if you know what you are doing the paint won't crack or ripple. I have done 3 sets with a bat, no issues.
Old 06-12-2013, 04:44 AM
99'CajunFirehawk157's Avatar
I have TTII's in 17x11 no mods at all and no fender roll but I hear firebirds rear fenders are diff than maros'...
Old 06-12-2013, 09:57 AM
apicia's Avatar
That what I have heard. The Trans Am has more room back there and does not need rolling. The SS needs only a minor roll.
Old 06-12-2013, 04:11 PM
leadfoot4's Avatar
Is the clearance issue on one side or both? If it's only on one side, you might want to install an adjustable panhard bar. The OE ride height of the f-bods is inconsistent enough, that an adjustable PHB is almost mandatory with larger than stock wheels/tires, no matter what....
Old 06-12-2013, 04:35 PM
LS1Tech Platinum Sponsor
rudytirerack's Avatar
Roll the fenders if done properly it causes no issues.
Old 06-12-2013, 05:43 PM
LILWS6's Avatar
I wouldn't mind a set in black for my car
Old 06-12-2013, 06:37 PM
apicia's Avatar
PM me with offers. I can ship them out via FedEx.
Old 06-12-2013, 07:00 PM
Donohue96M6Z28's Avatar
I'll rent you my fender roller for cheap.
Old 06-12-2013, 07:09 PM
ramair 1's Avatar
Rent the roller,use a heat gun and heat up the paint in the area to be rolled to allow it to stretch more easily .Take your time rolling it putting a little more pressure on the roller on each pass .Worked flawlessly for me id give it a try to allow for a wider wheel in the rear.I think it just looks meaner on these cars especially after lowering.
Old 06-12-2013, 07:14 PM
Blackpanther99's Avatar
Just rent a fender roller and bam. Done.
Old 06-12-2013, 09:09 PM
apicia's Avatar
Do you have a heat gun too?
Old 06-14-2013, 05:14 PM
stroked383HSR's Avatar
I didnt have to roll anything...or BFH anything either. I do have a TA though but there is plenty of room around the lip area. Im running 315's in the rear too. They are the Nitto 555r's and ive heard they are narrower than any other 315 so when i get a different set we'll see. Im also lower on Strano's too
but if you want you can check out my thread if you havent already ...its got plenty of pictures of the TTM's mounted.
https://ls1tech.com/forums/wheels-ti...zr1s-ttms.html
Old 06-14-2013, 07:01 PM
thatdude305's Avatar
yes!!!!!
Quick Reply: Brand New TTMs, Just Can't Roll...
