best 305/35/18
I was looking for this also and now I'm kinda stuck.. Have 18x11's on the way and don't really have the need for a drag radial.
Not sure why nitto doesn't offer them in non drag radial...
check out running a 315/30/18 many more choices...
I decided to go with 275/40/17 BFGoodrich Gforce KDW2s on the front and 315/30/18 BFGoodrich G-force Rivals in the back about $1100 on tirerack.com
and my wheels are $600 so its not bad
I looked at that option for a while... but I love the extra width of the 315/30s
looking at the specs 295/35/18 are 26.1 inches tall 315/30/18 are 25.5 inches tall so its definitely more then 1/3 of an inch. I also went with that size because there were a lot more tires in that size and honestly they were almost as wide as the 305's I had on there
.6 inches on EACH side of the tire = .3 of an inch.
I would say 1/3 of an inch is accurate.
(27.5/2.54)*.4 = 4.3307 => 4.3307+4.3307+17 = 25.6614
(29.5/2.54)*.35 = 4.0649 => 4.0649+4.0649+18 = 26.1298
(30.5/2.54)*.35 = 4.2028 => 4.2028+4.2028+18 = 26.4056
(31.5/2.54)*.3 = 3.7205 => 3.7205+3.7205+18 = 25.441
All of the 18in tires will have shorter sidewalls in order to accomodate the 18 inch wheel while trying to maintain overall stock diameter.
If you are looking at 305 35 18 drag radials, the nitto 555 drag is the longest lasting. If you are just after a regular z rated tire you will probably have to go with a 295 35 18. I had the kdw 2's on my car and they lasted a long time but as they got older they got slippery and loud.
