The Dark Stars Have Arrived
#41
Looks great, lowering makes all the difference in the world!
Good call on the MT's, in the long run you'll be happier with them. Run at least 23psi hot on the street and you won't even notice you're on a drag radial (unless of course you're trying to set personal bests on highway clovers
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#42
I knew it would look good and work without a hitch with the abs, but I admit I wasn't sure how it would look with the 275's up front since all the cars I've seen normally run a very noticeably narrower front wheel/tire package.
IMO, looks great, and the black chrome like finish is sweet!
![Burnout](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_burnout.gif)
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
#43
I'm going to order a full set of the Viking coil-overs here soon. That way, I can adjust the height to my liking and they are "on car" double adjustable. That way, I can get the look I want and tune them in to optimize traction.
#45
Edit: Here is one thread I was talking about; let me see if I can find the other one.
https://ls1tech.com/forums/suspensio...k-install.html
https://ls1tech.com/forums/drag-raci...ll-thread.html
#49
Thanks Dave. Yeah, clutch is all broke in and the car is tuned for kill mode. I'm hoping to get on the dyno next Saturday if all goes as planned. I wired up a Harlan shift light, so I tested it out a few days ago and works good. Set her at 6500 rpms.
#57
A PM is on the way.
#58
IMO, if you want some good front DD tires for a set of 17 x 7 front runners look at the following sizes in a V speed rating or higher.
215/50/17, H = 25.46"
215/55/17, H = 26.31"
225/50/17, H = 25.85"
You can also go with a 205/55/17, H = 25.88" but your tire selection is very small and they cost more than other sizes I listed.
#59
