What size DR for cam only M6 4.30's
So I just ordered my new wavetrac and 4.30's for my moser 9" and am curious about the perfect tire for an 1/8 mile track. Car is an '02 SS MS3 cam only 6 speed car making 390rwhp on a mustang dyno. My 295/45/17 et street radial II's are wore out so I am in the market for a new drag radial. I've used the fbody.org calculator but am still kind of iffy, any advice would be greatly appreciated!
I have 17x11 zr1's as my street wheels and a set of 17x9.5 zr1's with my dr's on them. My local 1/8 track is probably under 4 miles from my house so I'm not worried about having to swap tires there as I just swap at my house and drive. I'm thinking slicks just debating on what size and the argument of bias slicks on the rear with 275/40 radial street tires up front
Yeah I've heard some horror stories from some about mixing the 2 and I've also heard "it's fine just don't air down much" lol I think I'll just invest in some weld's so I can run slicks and skinnies and sell my 9.5 zr1's
It depends... You're power/cam/gearing are about the same as mine. I am actually going to a 27" tire to see if I can 60ft and ET better. I have my limiter set at 6800, so even with that tire height I still have enough rpm to go over 120mph through the traps. If/when I spray, I will put the 28's back on. If you are going to add a bunch more power soon..go with 28s. The MS3 wants to pull hard up top, the closer I can crowd my limiter through the traps the better. Don't stay with drag radials unless you want to beat your head against the wall for wasting the money. Try a Hoosier Qtp or MT ET Drag slick with some matching bias fronts and don't look back. I daily drove MT ET Street Bias plys all last year and dont regret it one bit. Just my 2 cents. Good luck!
