26" or 28" tire with 4.10's m6
My car has 400whp and im running 4.10 gears with a m6, I was going to order some tires and wheels for the strip soon and was wondering what tire size would be better the 26" or 28"? Thanks for any help
I was wondering the same thing for my set up. I went 114.69 on a 295/35/18 which I think is 26.1" tall. I have Moser rear with 4.11 and m6 also. Don't know exactly where the limiter is set but its probably 6500.
Im at 446 RWHP and 4.11 gear. running 26" tires shifting at 6800 and crossing the line at 125-127mph. The MT et street bias ply will be a better track tire for you, unless you have adjustable suspension and your good at dialing it in.
ski, assuming you have an m6, what gear are you in when you cross the line? Im at the top of 4th and im not sure what the limiter is set at since I just bought the car and it was tuned by previous owners place
Running all motor go 26" all day long. I run 26" ET Drags Stiffwalls and have done fairly well. ET Street Radial will be VERY hard to hook with an M6 car, but a few people have done it with proper suspension. Definitely go Bias Ply if possible. If you think you're going to start spraying before you wear out the 26" tires, jump into the 28" tires first.
I trap 116, my rev limiter is set at 6800, and I run 28" tires. I go through the traps just a tick over 6k. If I had to buy another set of tires, I would go 26" all the way. I am planning on spraying, so 28's will give me the mph growth room I will need. Don't rule out 27" QTP's.... lots of guys stuck in the middle seem to run those with good results without going to a full slick
