Pheonix or M&H front runner? bias ply vs radial?
I have been searching and searching like crazy and cant get a clear answer. Most people say radial skinny front and bias ply rear are fine and don't have sway - then several people say you must run bias front if bias rear even if skinny. I'm so damn confused.
I drag race a C5 Z06 & a Gbody Buick Regal & have 17x4.5 front and 16x10 rear CCW classics - I use the same set of wheels on both cars. I like to drive the car to the track (30 miles away one way) on the drag pack - I'd figure 2 trips per month to the track, that's about the only street miles they will see, otherwise I will be in street wheel/tire trim.
I am thinking about giving these new Phoenix 17" front runners a try
http://www.jegs.com/i/Phoenix-Drag-T...PH427/10002/-1
or the M&H 17" bias front is about $60 more per pair
http://www.jegs.com/i/M-H/676/MSS-01...2/-1#reviewTab
can I get some thoughts or opinions? Hoping to order by this evening
