Need help with Torq Thrust back spacing
Old Jul 7, 2016 | 12:59 PM
THE LAST Z's Avatar
Question Need help with Torq Thrust back spacing
I want to do a 17 x 8 up front and s 17 x 9.5 rear. The rears should be 7.06 back space correct?
The fronts give me an option of 4.07 and 4.81 for a 17 x 8. Wich ones should i get?
Old Jul 8, 2016 | 06:08 AM
leadfoot4's Avatar
As I recall, the OE 16x8s had a backspace of approximately 6", so I would think that a wheel with less than 5" could possibly have the tires colliding with the fenders. At one time, I had 9.5" rims, all the way around, on my '96 Z/28, and they had a 6.75" backspace.
Old Jul 9, 2016 | 01:35 PM
THE LAST Z's Avatar
The 17x8 gives me a choice of 4" or 4.75 back space. I would say 4.75 right?
Old Jul 10, 2016 | 08:45 AM
badfbodyz's Avatar
I would try to get something over a 5" backspace for the front. And the 9.5", either the 6.5" if you go with 5" backspace on front , or 7" if you go with a bigger backspace up front. Cause the LAST thing you want is for the front wheels to have a deeper dish & stick out further than the rears.....gotta say though, your doing an odd size with 8" fronts 9.5" rears. Most on here do 9.5" all around, or 9.5" fronts and 11" rears. If you go that 9.5/11" route, do 7" backspace fronts, 7.75 backspace rears
Old Jul 10, 2016 | 09:30 PM
THE LAST Z's Avatar
I saw someone on here that did a 17 x 7 in the front and a 17 x 11 rear. Looked pretty bad ***. I could also do a 17 x 7 front with a 225-50-17. and 17 x 9.5 rear. I just don't know what backspace I would need for a 17 x 7 front.
Old Jul 12, 2016 | 06:27 AM
leadfoot4's Avatar
I guess a better question would be this....Are you looking to set up the car for better cornering, or more of a drag race deal? That would dictate what you should be looking at, in terms of wheel widths and tire sizes.
Old Jul 13, 2016 | 04:10 PM
THE LAST Z's Avatar
Drag race. I like the torq thrust. Not to expensive and they look ok...
Old Jul 18, 2016 | 01:44 PM
THE LAST Z's Avatar
I want to do 17 x 8 up front with a 245-45-17 tire because of tracking issues.
Old Jul 18, 2016 | 11:16 PM
badfbodyz's Avatar
If doing a 9.5" rears with what I assume is the 7" backspace, then you need 5.5" on an 8" wheel or 4.5 on a 7.
