I have a 2002ss I want the exact wheel . I see a lot of people asking bs and offset and bolt patterns. some are giving part numbers I just want to know which is right to fit the car without grinding this and that I would like a skinny up front or at least a 7 inch wheel either 15s or 17 don't matter to me just want to bolt right up without the front tires sticking out to far any help pleasssss
So an oemfitment f body wheel has 7.5 bs.I think they offer a 6.5 bs in 15x10,not sure how much that would stick out and if they would rub.So if someone was ordering billet specialties for example,does one usually go 15x8 or 15x10?
Im seriously considering a set for my 2000 SS......
ive got the vision 571 Sport Star II .. the front 15x4 and they dont fit on my 2000 ls1 camaro ss...i need to grind the galiper a lot and get some hub centric rings 70.3mm tu 83mm for proper fittement... the weight of the wheel is 13.5 pounds ...not bad and went with M&H DOT they weight 12.8 pounds.. still waiting for the rear 15x8 they are back order
Here's my car with weld prostars. 15x10 with 6.5 BS
Had to grind the hell out of the calipers to fit. They sit inside the fender with no spacer but they're super close to the brakes.
With a 5/16 spacer they will clear the brakes with minimal grinding but will scrub if I hit a big bump and have a buddy in the car. I'd say 1/8" spacer would be the best blend of caliper grinding and fender fitment.
Had to massage the inner fender lip, but that's it. No fender rolling.
I can get a picture showing the "tuck" if you need
i just recive the rear ..15x8 .... 5.5 backspace .. no grinding needed ..they weight 15.6 pounds...so far so good...now waiting for mt 26 - 10.5x 15 ET STREET R BIASS PLY DOT
its 15x4...1.75 backspace....yes a bit of grinding.... they sell 17in that dont need grinding..but they are heavier......with theses mags and tires combo,,,i save a total of 58 pounds of rotating mass vs stock !!!!!
