Jegs new SSR Spike wheels, installed.
Jegs introduced this new wheel for pre-order while back. The fronts I got pretty quick, but the rears took a few weeks. I got the rears yesterday and got new tires mounted up. I think they look great for the price!!!
![Name: BB1456D1-980F-4B22-AF59-6B33E14DD3B2_zpswplsvhjz.jpg
Size: 179.6 KB](https://ls1tech.com/forums/attachments/wheels-tires/585830d1501206370-jegs-new-ssr-spike-wheels-installed-bb1456d1-980f-4b22-af59-6b33e14dd3b2_zpswplsvhjz.jpg)
![Name: 508A6192-DBE4-40E0-A33C-CC0C7F0A4441_zpse0cyfmev.jpg
Size: 173.6 KB](https://ls1tech.com/forums/attachments/wheels-tires/585831d1501206370-jegs-new-ssr-spike-wheels-installed-508a6192-dbe4-40e0-a33c-cc0c7f0a4441_zpse0cyfmev.jpg)
![Name: 63592812-D0BE-4D3E-8CAF-4F7934913FE5_zps8kdhotww.jpg
Size: 141.8 KB](https://ls1tech.com/forums/attachments/wheels-tires/585832d1501206370-jegs-new-ssr-spike-wheels-installed-63592812-d0be-4d3e-8caf-4f7934913fe5_zps8kdhotww.jpg)
![Name: 18052925-1903-4069-8FEB-0D1687A3363B_zpsh4wmusen.jpg
Size: 186.3 KB](https://ls1tech.com/forums/attachments/wheels-tires/585833d1501206370-jegs-new-ssr-spike-wheels-installed-18052925-1903-4069-8feb-0d1687a3363b_zpsh4wmusen.jpg)
Before people loose their **** about Jegs wheels being made in China, and the weight, and all that garbage, these are just for the street pretty much. For the price, you can't beat it!!! I have a full set of Welds for the track.
![Name: Paul111_zpsgpbshafy.jpg
Size: 244.1 KB](https://ls1tech.com/forums/attachments/wheels-tires/585834d1501206370-jegs-new-ssr-spike-wheels-installed-paul111_zpsgpbshafy.jpg)
I picked up a set of the SSR Mags. I noticed them on Jegs, looked up the part number on Summit and they were almost half price. I'm a sucker for a $400 set of wheels. Turns out they are made by Vision wheels and Jegs spas a sticker on the center cap. Quality seems decent enough, they are rated higher then Race Stars and certainly look better. Compared to my old race stars and my friends Welds there is only a 2lb difference which doesn't matter to me. Oddly enough the Welds take the most weight to balance so the overall difference is even less then a lb.
nice...what width,backspace and offset you go with?
hoping I can get mines to sit like yours with this setup on a stock rear end
Diameter & Width: 15 x 8"
Bolts & Bolt Circle: 5-4.75"
Backspace: 4.5"
Offset: 0mm
Hub Bore: 3.27"
Backspace: 4.5"
Offset: 0mm
Hub Bore: 3.27"
I ordered the wrong wheel and wasted by money, had to re-order the right one!
I know I'm bumping an old thread but...how well did they clear the brakes?
Did you have to do an crap ton of grinding on the calipers?
