Best Handling tires?
Old May 16, 2017 | 01:14 PM
blackws620's Avatar
Default Best Handling tires?
Hey guys I'm looking to get out of the straight line game and start throwing the WS6 through the mountain roads. What have you guys found to be the best handling tires for the street? Money isn't a huge issue but I would still like the best bang for the buck. Thanks for any info
Old May 16, 2017 | 08:21 PM
capelajc's Avatar
What do you have for performance mods and suspension upgrades? I think it would depend on what you already have done that will determine what tire you will need. I have suspension and just did H/C LT'S and convertor and also looking for a good set of all around good handling tires that will hold the extra RWHP now. I'm leaning towards the Nitto G2's so far from research I've done....but I'm still waiting to get my car back
Old May 16, 2017 | 09:16 PM
Chris Paveglio's Avatar
What size? I've got some Bridgestone RE760s and they are pretty good, 275/40/17. Never tried Michelin but I would.
Old May 16, 2017 | 09:34 PM
JD_AMG's Avatar
Depends on your budget, wheel size(certain tires are only available for certain height and width wheels) and how streetable you want the tire to be (rain? ride quality?).
Also consider that ideally you want to be wide for these cars, 275 come from the factory and if you are truly serious about it guys are running 315s on all four corners (very little modification to do so). And if you are that serious anyway Id hope you have a good suspension setup along with it as the factory setup is pretty poor (especially the shocks) and many aftermarket parts can hurt handling or do you no favors. You would be absolutely blown away with what a proper setup can do to these cars.
With that being said I hear nothing but good things about Michelin Pilot Sport tires(Cup, PS2) but you are talking about ~$350+ per tire. Also bfgoodrich g-Force Rival S seem to be a very popular track tire, but I don't know how they do on the street and again are pretty expensive the properly wide ones for our cars are only available in 18s.
On budget something like NT05s are pretty cheap and grip well, especially if you are just street driving. NT555 G2s would be good to on budget and should be more street friendly/last longer than the NT05s but will give up grip to do so.
Old May 17, 2017 | 10:54 AM
blackws620's Avatar
Awesome thanks for the info. I am putting down just over 450 to the ground. I'm running 275's all the way around on a 17" wheel.And I have Tunnel mount torque arm, 3 point subframe connectors, Tubular PanHard bar/relocation, Eibach pro Kit springs. And the beilstein shocks still, and 35MM/22MM front and rear sway bars. What shocks would you guys recommend also, and What other suspension stuff would you add? I already got the LCA's on the list.
Old May 17, 2017 | 05:54 PM
DemonicZ's Avatar
If money is no concern go with Koni yellows for shocks/struts
Old May 17, 2017 | 08:21 PM
JD_AMG's Avatar
Koni single adjustables and strano springs would be a big improvement. Your 35/22 swaybars are perfect, but trade the tunnel mount torque arm for a full length one. You don't need LCAs for handling, they will do little to nothing for that. If you have the cash a watts link is also a big improvement as well.
For tires on your current wheels they have pilot sport PS2s available but like I said they are like $350 a tire. Nitto NT05s are a good value at less than $200 a tire and I have no complaints about the ones Im using now.
Then you have more race style tires with 100 tread wear like toyo porxy R888 or like the nitto NT01.
Old May 18, 2017 | 09:02 AM
blackws620's Avatar
Okay thanks for the info guys. My exhaust wont allow me to run a Watts Link. I have 3" True Duals out the back so its not really an option. And I have wanted to trade my tunnel mount TA for a Full length since I put it on. I hate it. I'll look into the Koni/Strano setup. And i'll probably shoot for the Nitto NT05's
Old May 18, 2017 | 11:39 AM
M4N14C's Avatar
MWC watts link is designed for clearance of a dual exhaust setup. I'm currently running TSP duals which are dumped before the rear axle but you can tell that I could have easily gone over the axle and out the back
Old May 18, 2017 | 12:24 PM
PJD1975's Avatar
I have used Nitto tires for several years now and have been very pleased with their performance. And they are pretty decently priced which is always a plus.
Old May 18, 2017 | 01:16 PM
AnotherWs6's Avatar
I have NTO5's on the front of my car, only reason to go with them was to match with the NT05R's on the rear. While I have zero complaints about them in all fairness I haven't pushed them hard. I bought them DESPITE them doing abysmally in a HotRod tire test....
http://www.hotrod.com/articles/the-b...ar-tires-test/
Old May 18, 2017 | 05:05 PM
stp001's Avatar
Falken Azenis 615+ in a 275/40/17 An upper tier autocross competitor at Walmart pricing.
Old May 20, 2017 | 01:11 PM
rudytirerack's Avatar
LS1Tech Platinum Sponsor
Very good Dry grip on that Falken. Michelin Pilot Super Sports, Continental Extreme Contact Sport are a couple other good options.
Old May 20, 2017 | 02:29 PM
DemonicZ's Avatar
I've run NT05s and R888s love them both
Old May 20, 2017 | 06:53 PM
2JAWZ's Avatar
I faithfully believe in the Nitto NT05's for corner carving! Ive had two sets on two different cars with two completely different suspension setups and they held the road great on a car with just springs as they did on my current car with full UMI suspension and Fays2Watts link!
