275 35r18 - which offset would be best for 18" ?
Old Jun 23, 2017 | 11:17 PM
camar0rs's Avatar
Question 275 35r18 - which offset would be best for 18" ?
Rims will be 18x9.5
Seller currently has it on the invoice for +40 offset, should i keep this or +35 ?
2000 TA
Old Jun 24, 2017 | 04:18 PM
dojob's Avatar
+35 will look better
Old Jun 24, 2017 | 05:50 PM
camar0rs's Avatar
if i understand correctly, the shorter the offset the tires go out more right?
Old Jun 25, 2017 | 09:54 AM
RedDeadG8's Avatar
what size tires will be used? +40mm offset will work and gives you room to add an adapter down the road if you choose to make the wheels stick out farther. being lowered or stock height and the size tires used all make a difference. I recommend staying with +40mm offset.
Old Jun 25, 2017 | 10:35 AM
camar0rs's Avatar
tires are 275 35 18
car is already lowered i believe 1.5"
Old Jun 25, 2017 | 07:17 PM
dojob's Avatar
+35 then
Old Jun 26, 2017 | 10:07 PM
RedDeadG8's Avatar
i run the Forgestar CF5's with 275/35/18 tires on all 4 corners. They are 40mm offset and never have an issue. they do no stick out past the fenders and sit just inside them, which is what I prefer. I am also on the Koni/Strano setup. the difference between 40 and 35 offset is negligible, maybe a 1/4 inch further push out with the 35 over the 40.
Old Jun 27, 2017 | 08:11 AM
camar0rs's Avatar
did you roll your fenders?
Old Jun 27, 2017 | 09:34 AM
dojob's Avatar
i run 285/35/18 18x10.5 +38 on strano springs. no issues. no rolling or rubbing
Old Jun 27, 2017 | 07:23 PM
RedDeadG8's Avatar
no rolling fenders
