Slicks vs radials
Slicks vs radials
So I was talking with a friend of mine today and he said that a full slick is easier on the rear end than drag radial kinda surprised me, I figured it would be opposite sense a radial wouldnt hook as hard as the slick but somthing about the sidewall being stiff on the drag radial makes it tougher on the rear axle any truth to this? seems to make some sense
Hitting a slick with power is like punching a pillow, have you ever seen a slick up close? I make a slight turn into my garage with a spool and one slick literally sits there wrinkled because its in a bind. A radial tire would NEVER do that. They either catch or spin, but once they spin you're done. A slick with spin some then grab to keep you from getting out of shape most times. Also, when a radial hops, something is gonna break....
Here's what wheel hop and a hard *** radial does to ****:
All one side bent
drivers side broke
All one side bent
drivers side broke
All one side bent
drivers side broke
All one side bent
drivers side broke
Alot of people told me to go radials because I have an auto car, but I'm glad I went bias ply. I do alot of stuff on unprepped areas and the bias is so much nicer.
The myth that slicks are harder on your drivetrain is a retarded internet myth that keeps getting spewed by people who maybe just dont know any better.
I have always ran radials. The newer MT's like the pro and et street r, as well at the hoosier dot dr and d2 are more forgiving. They have a softer side wall but still not as soft as a slick. The slick will always shock the driveline less. On the flip side the slick will sway on the top end. I will choose a radial over a slick any day.
