19" rims - thoughts?
I've got a 2000 WS6 with stock 17" rims. I want bigger rims but for the cost, 18" doesn't seem like it will make much of a difference. But 20's just seem TOO big, so I settled on 19".
Which are nearly impossible to find.
So, does anyone have 19's? What are your thoughts?
The following users liked this post:
fucter (12-27-2021)
LS1Tech Administrator
Received 1,493 Likes
My thoughts are that 19s are too big for these cars. I've seen several pictures of them on 4th gens, and every time my first thought is how much better they would look in a 17 or 18 (and even 18s are pushing it, though they can look very nice with the right design and a slight drop.) I would never consider anything bigger than 18" for a 4th gen, and even then only because 17" tire selection isn't what it used to be.
But it's all just a matter of opinion.
fucter (12-27-2021)
I love my 19's on the rear of my car. The biggest thing I don't like about them is they sometimes make my front 18's look smaller than 18's should look like on these cars.
Both cars above would look much better with 18s all around IMO.
simply one of those to each their own questions. i think some 17" wheels look really lame and leave too much to be desired, as others look great. i think some 19's look horrible & others great. i think MY 19" rear & 18" front setup looks great & wouldn't change it anytime in the near future. sure some may hate it .... i don't care, as neither should you - look at a good amount of pics of 19's on f bodies/your specific car - of course in person if you have that opportunity, then make your decision. you will simply get mixed reactions here both hating 19's & loving them
That's just it......it's right there on the verge of starting to look retarded like 24s on Chrysler 300s.
Hell I'm not a fan of the 20s they put on 5gens. Zr1/1le's don't look bad wuth their 20s. I hate the staggered diameter on the vettes to.
Oddly enough a 17 front 15 rear combo looks great. But that's meant fir da bizness.
The 18front 19rear combo is meant for nothing......even hurts da bizness with less rear sidewall.
What works on other cars won't always work on these cars.
Also you clearly have not searched this forum or used google. There are thread with hundreds of posts and pictures with 4th gens and 19" wheels or at least wheels available in 19s that fit our cars.
here ya go ..... a good amount of people running them & perfectly happy with both the performance & looks of them... https://ls1tech.com/forums/wheels-ti...st-pics-3.html
To be honest I generally am not fond of a staggered setup but for whatever reason I think it looks pretty good on a Fbody. With that said if factory C6Z wheels came with a 18x12 wheel on the back then that's what I'd be running but Vettes usually come with a staggered setup and the shape of the spokes and offset/backspacing of the Vette rear wheels look much better on the rear of a Fbody than the Vette front wheels and that's not even considering the fact that you are trying to run wider tires on the back. If high-end aftermarket wheels didn't cost more than what I'm willing to spend I'd be running some nice custom 5 spokes. The typical 9/9.5"wide wheels have straighter spokes and aren't taper outward to move the wheels closer to your rear fenders. With a 9/9.5" wheel you have to run a lot of spacer to get them close to flush with your outer fender. With factory C6Z F/R wheels no spacers are required to get the rear wheels flush with the out fenders and the front backspacing/offset/spoke design easily clears your factory 14", 4 piston Brembos without needing spacers. They clear with probably a 1/4” to spare. I could likely run the 6 piston Brembos without needing spacers.
The biggest problem in my experience with running a different height tire F/R is that the ABS can get confused and want to start kicking in when hard braking at fast speeds. If you don't need ABS this becomes a non-issue if you delete it, but if you want to keep your ABS then it's something you need to consider before going staggered if that's what you are looking to do. Some cars don't get ABS problems with a staggered tire height whereas some do.
Even though some people on here don't like them I'm constantly getting people coming up to me complementing my cars. It's gets kind of aggravating as people want to have 20 minute conversations on cars and try telling me all about what they've got. Build your car how you want. It's your money so build it how you want it.
Larger wheels can look fine on cars that were originally designed with them in mind (including such aspects as belt line, body curvature, door sill height, etc.), and with larger overall tire diameters which allow for taller sidewalls.
Here's mine on 18x9.5 all around.
19s all round isn't the end of the world but a 18/19 combo is awful. I don't like the 19s in general because i don't like this all rim and no tire look. Not to mention they typically get heavier which hurts performance.
My personal opinion is 19" wheels are a tad large for f bodys. Maybe a bad *** set of 19" HRE's may change my mindset. I myself happen to be in the 17" wheel fanclub.. (Street lites).. I will say HioSSilver's 18"s are some of the nicest I've seen on an fbody. Can I ask what tire sizes you went with?.
