Toyo proxes r888 vs. Nitro 555r
#41
Well now I'm stuck knowing 315/30/18 may fit.. I have 56mm offset 18x10.5" wheels. The price on 315 r888r and/or TQ is cheaper than the 305/35/18 555r and you get more tire for the money. Another bonus is tire height is very close to stock for running ABS, which I still have.
Worst case i guess I have to roll my fenders (hopefully not), BFH mod, and trim my bump stops.. I looked all over for info on people running 315/30/18 and I get a ton of threads asking about fitment and then they never come back and say if it worked or not lol. Can't find anyone who has done it without being lowered, which ends with them having to roll fenders every time.
Do most body shops roll fenders? Where is everyone getting it done?
#42
Alot of guys end up doing it themselves with a special fender rolling tool. I believe some members offer to rent them for a fixed price on this site. It's not too difficult of a process. If that's not for you, I would think a body shop could handle it. Good luck.
#43
#45
Given that you're only lowered via heater hose... The tire will be running right at the bump stop. Even with trimming it was close with my 285/35 tires on 18x10.5 +58 wheels.
I run 20mm spacers now. Tires/wheels flush with qtrs now. Adjustable panhard required to center it just right too.
For 295s at least run at least a 5mm spacer to be safe on the inside and play with panhard bar. Outside you're fine
#48
Sounds good I will stick close to my current size then. I'm willing to BFH mod and cut my bump stops, but would prefer not to run a spacer and roll fenders. I do run longer wheel studs so a spacer could be a good back up plan for me if I can't get it to clear. I'm thinking the 305 555rs will run closer to a normal 295 so i may just go that route so I'm not running a 25" tall 295/30/18 which may look a little short in the rear. Never knew tires would be such a hard decision lol
#49
#50
My 295s fit right now with no rubbing or spacers.. when I jack the car up it does hang on the bump stop though. Maybe my 295s fit because they are nittos and run small? I think cutting the bump stops is more or less trimming the lip that sticks out, which doesn't look too risky to run that way.
I was just reading a thread where 315/30/18 fit with the same offset as my wheels with just BFH mod and no spacers.. bump stop may have been totally removed though. So many different reviews and threads that it makes it more confusing lol. I'm about to roll the dice on 305s or 315s and do what is needed to make it fit.
#51
Trimming the lip helps, yes. Just don't completely remove them
315/30/18 with a 56 offset and 10 mm spacer should get you right where you need to be. Minimal rolling and hammering
#52
Correct, when you jack it up or the suspension articulates (Like going in/out driveway or an entrance) it will hit.
