Plasti Dip removal over chrome
So I've been trying to remove it from some topline c5 z06 wheels. Chrome looks pretty bad but I thought I'd just polish them up once I was done with the removal. But some people are telling me I can't polish chrome....am I missing something? I don't know what they mean. Aluminum yes, chrome no
Chrome is a metal coating usually over aluminum on wheels, it can be polished just like any other metal. The problem with chrome is it's a thin plating so if it's chipped or damaged it can't be fixed. Aluminum is not a plating so it can be repaired and polished over and over.
Ok i see, so the easiest way to go about my situation is just remove this damm dip and have them polished? I was thinking I would have to get them stripped and re chromed.
Oh that's fine, I just needed to know where I stood with the wheels. I might end up painting them black once I paint the car but that's another issue. Right now I'm having too much of a hard time getting the dip off. Neon Green!
I actually talked to a powder coating shop that also do blasting, and they said blasting the chrome wouldn’t work. It would need to be stripped with chemicals. Besides the fact they would charge about $200/wheel to do something like that.
If the dip was applied too thin and it isn't peeling cleanly, you can spray it with WD-40 and let it sit for 5 minutes then just spray it off with a pressure washer. Maybe even a normal hose with a jet setting.
It will dissolve into a slime and come right off with just water, no scrubbing or peeling needed.
I would just remove all the dip, give em a scuff sanding, and hit em with a self etching filler primer, then a heavy applying ceramic black spray like rustoleum. They will look great until you get right on em, even if you don't have much experience since the filler primer and rustoleum ceramic both apply thick and fill a decent amount of imperfections.
That's how I did an ugly pair of craigslist wheels I used for a swappable drag setup before I went to just running 24/7 RTS's. Even with barely any prep and no sanding after the primer layers (they were only for the track and I didn't care how they looked) they came out surprisingly well.
