98-02 Compact Spare Replacement
Old Apr 14, 2019 | 05:38 PM
  #41
Y2000TA's Avatar
Originally Posted by Saturn5
Outstanding!
Installed it back into the hatch and it fit like a glove. That thing has been blown out for 3 years.
Old Apr 28, 2019 | 04:25 PM
  #42
Kjduvall's Avatar
After reading this thread I went and checked my spare. Wow was I glad I looked at it. Oh well it is 19 years old and never been used.
Old Apr 28, 2019 | 05:07 PM
  #43
sjsingle1's Avatar
found all 3 of mine like that.....rubber dont last forever !!!
Old May 23, 2019 | 03:20 PM
  #44
bsf's Avatar
bsf
Y2000TA,
Did you check the date code on the tire? Can you tell us what it is?
Anyone else get the Continental CST17 T125/70R16 from TireRack and check the date code?
I intend to utilize the 5/24-5/27 Discount Tire Memorial Day Weekend 10% promotion to get BFG G-Force Comp 2 A/S tires to replace the 21 year old OEM’s on my WS6. Trying to figure out where to purchase a spare. Discount does not show T135/60R16 or T125/70R16 as available on the consumer website. However, my local store checked their database and show some higher priced options in one of those 2 sizes as potentially available. Employee was not certain they could match TireRack CST17 pricing of $112.90, though.
Old May 28, 2019 | 11:34 AM
  #45
Saturn5's Avatar
I ordered the T135/70R16 from Tire Rack. I'm having it mounted today. No, I didn't think to check the date code. I'll do that when I pick it up this afternoon.
Old Jun 1, 2019 | 04:40 PM
  #46
Saturn5's Avatar
Update, my spare that I just got from Tire Rack I believe has a 2012 date code. I wish I'd checked it before having it mounted, but it's better than nothing.
One other downside of note, the T135/70R16 is too big to fit in the spare tire well. I didn't think the 1/2" or so of additional tire height would make that much of a difference. I'll futz with it some more to see if I can make it fit. I'd rather have the taller spare than a narrow and shorter T125/60R16 if I can make it work. I carry a small air pump with me. I may try letting the air out of it to see if it'll fit that way and pump it up if I need to put it on the car. I'll keep an eye out for a factory size replacement either way unless I go with 18 or 19 inch wheels in the future and use run-flats. It wouldn't be that big of a deal around town, but I like to take the car on road trips and no spare on a road trip is just not something I want to do, even with AAA.
Old Jun 1, 2019 | 10:50 PM
  #47
bsf's Avatar
bsf
One other downside of note, the T135/70R16 is too big to fit in the spare tire well....
Thank you for the update. Very helpful information. I wish Y2000TA would check back in and provide the date code on the T125/70R16 from TireRack.
Old Jun 11, 2019 | 05:28 PM
  #48
Saturn5's Avatar
By deflating the tire, I could just barely fit it in the spare tire compartment. The T125/70-16 is probably a better option if the factory size isn't available.
Old Jun 11, 2019 | 06:35 PM
  #49
bsf's Avatar
bsf
Thank you for letting us know. I am probably going to stick w/ my 1998 spare for a while longer. I already had my appointment w/ Discount Tire and did not do anything with the spare. Prices on the T125/70R16’s the Discount salesman pulled up in-store were $140’s and $150’s plus labor and disposal. I am not going w/ TireRack if those tires are 6-7 years old already.
Old Nov 2, 2019 | 02:01 PM
  #50
wicknewman's Avatar
For anyone still looking for a decent spare tire replacement I purchased the Hankook 125/70R16 from tire rack. It has a date code of 1319 and a little wider tire tread than the Continental. Also about 30 bucks cheaper.
Old May 5, 2023 | 11:53 AM
  #51
bbaz's Avatar
Just had mine blow out while in the hatch. Never used. I thought someone had shot my car (I live in Arizona, so that's always possible). Are you certain this size will fit in the notch in the side of the hatch?
Thanks
Old May 5, 2023 | 03:08 PM
  #52
pdxmotorhead's Avatar
May or may not help, but Porshe uses a 17" spare thats one of those ones you need a compressor to inflate before install.
If a guy could find the right wheel maybe it's an option? its not real wide, Look at early 2000 Porsche 911 spare tire..
Old May 6, 2023 | 12:29 PM
  #53
FirstYrLS1Z's Avatar
Active Streak: 30 Days
My spare, always in the car, back seat folded down, I do a lot of travelling. The compact spare is in it's normal location.
Old May 13, 2023 | 12:08 PM
  #54
bbaz's Avatar
Just bought and mounted that tire and it "depends" on what you mean by it "fits". Yes, it will fit in the spare tire well on the side of the car. "No", you can't lock it down with the twist nut and rod like the original tire and "No" it doesn't fit well underneath the rear plastic trim. It causes the trim to bulge and look stupid. I'm looking for the OEM look, as I wouldn't ever use the tire but I wanted my car "complete". It's in excellent condition. Everything is original, undented, scratched, marred....except that I have no spare tire.
Old Sep 4, 2024 | 07:04 PM
  #55
spoookee's Avatar
Default I'm green, super green, so...
Originally Posted by LS6427
There are a bunch of spare compact tires from foreign cars that will fit into our factory wheel well compartment......then all you need to do is buy an adapter wheel spacer that converts GM bolt pattern to whatever foreign bolt pattern you're using.
If you ever need it...pull you r tire....pop on the adapter plate....bolt the wheel on and go.
okay like I cannot find a spare tire that size to save my soul that's under $200 and there's very few that's available at all. I do keep on repeatedly pulling up a similar size tire but they came off of Nissan Seneca I think it is every time. So, if I understand this, I'd buy the Nissan spare tire which is 5x114, and, I'd buy a "spacer" or "converter" that is 5x120 (GM). That converter show attaches to the face over the lugs then you fasten the new 114 sized posts. Am I understanding that right? And this doesn't mess w brake placement or anything?
Thanks for any advice. Losing my mind trying to find a spare.
Old Sep 12, 2024 | 10:52 AM
  #56
Jolly's Avatar
Never seen this thread. Wow. These cars never seem to stop impressing me. First my front emblem deteriorates and "melts" off then now the spare just falls apart. I guess after 25years I should actually pull it out and check it. Probably blow up in my face
@@spoookee
Search for the Continental SContact version T 125 /70 R16. Found it for $135 at DisTire.
Old Sep 14, 2024 | 11:43 AM
  #57
Treburkulosis's Avatar
@@spoookee
Mine actually has never been on the ground lol. I aired it up the other day. If I had to go a few miles with it on I would. Its in great shape.
Old Oct 7, 2024 | 06:59 AM
  #58
Jolly's Avatar
Well mine had zero pressure in it, looking at it for the first time in 20years. Probably why its still in good shape I guess. Put 40psi in it and will see how it goes. If it holds up I'll probably leave it. The rubber had bloomed and was white inside the treads so Its certainly not 100%.
Old Oct 8, 2024 | 12:37 PM
  #59
TA_Freak's Avatar
See this thread: https://ls1tech.com/forums/wheels-ti...-trans-am.html
Originally Posted by Finkledbody
Tire rack sells a 125/70/16 22.9” tall vs 22.4” stock . 2.2% difference.
Fits perfectly in the spare tire location on the `99 TA. I think it's 1/2" taller than stock.
