335s and stranos on Camaro
Anyone do it? I think it may be my winter project. I really don't want to have to mini tub my car. I'm fine with beating the crap out of my wheel wells.
I have my 335 tires mounted on my 18 x 12.5 rims. I test fit them already, I just need to cut a part of the inner wheel well wall out and weld a flat steel plate in its place.
I will be selling a kit for about $150.00 that will include what you need to fit those size tires. It will have a pattern that you use to cut the metal part out, and it includes the exact fit steel plate to weld back in. Should take 20 minutes per side to complete.
Only thing it will not include, but is required, is a set of offset LCAs. You will have to buy those. Or spacers if you want the tires to sit in a different spot.
No need to mini tub to fit 335 or 345 tires. I know I've been taking forever with mine, but I just can;t seem to get my *** home from working out here in the **** Middle East.
$24.95 for a set of offset sleeves......put them into almost any LCAs......except factory LCA.s. UMI makes them.....
http://umiperformance.com/catalog/in...roducts_id=108
Or buy some very good thin LCAs from Founders Performance (IIRC $119.00) to put the UMI offset sleeves into. Gives you even more room for big tires.
