Will these fit
18x8
Will these rims fit my 2000 Z28?
They are 18x8. Please post a picture of your car if you are running these....
thanks
Product Specifications:
Product ID: ALY5758
Product: Wheel/Rim (Single)
Material: Aluminum
Style: 5 Spoke
Finish: Powder Coat Silver
Rim Material:AlloyBolt Pattern:5x120Rim Width:8.5Hub Bore:66.9Rim Diameter:18Rim Structure:One PieceOffset:+32Quantity:4Number of Bolts:5Rim Brand:Chevrolet
Lugs: 5
Bolt Pattern: 120mm
Indents: ABDS
OE Part Number: 22998072
no point in buying a wheel that is the same width as the factory wheel you are replacing it with. as said above, save up for something at least 9" wide otherwise just keep the factory wheels. my .02
When I bought my car, it had a set of 20" wheels that were not going to work for me. I found a set of 18s off of a 5th gen and paid a hundred bucks for them and painted them gunmetal gray. They're different than the ones you posted. They're not super wide, but I put a set of tires on it that were stock width and height.
I don't intend for this to be the car's "final form" or anything, just a temporary thing until I can save up for what I really want. You can see them in my profile picture.
I mean by the time you buy these, and machine them to fit you couldve just picked up a nice looking set of 4th gen wheels or some decent ones off of craigslist.
Those probably wouldnt fit without spacers anyway looking at the offset. If they did they will be tucked deep.
Ok,..Im going to break down and go into more debt.... I really like the torque thrust II look,..and found these, they look great and cost less than Torque Thrusts... Anyone running these Ridlers on there 4th gens?
What wheels do you have now? There are always 4th gen rims in the classifieds. You could probably find something with decent tires and still spend less than that, just saying.
https://ls1tech.com/forums/market/1911832
https://ls1tech.com/forums/market/1911066
BTW, fastenal will ship big things on a crate for under $200 pretty much anywhere in the country.
https://ls1tech.com/forums/wheels-ti...must-read.html
this is what i would suggest if on a budget, find something used that has decent tires. also, you are still looking at a factory width wheel for the front (smaller than factory on SS and WS6 models). these cars love more tire (ie wider wheel) in the front for good handling, if that's your thing
Ok.. Thank You guys for the great info..!! I heard back from the ebay Ridler rims.. They say the front backspacing in 4.5” and the rears are 5.5”... Wish they would have sent the info in millimeters . Im confused because when I convert inches to millimeters I get #s that dont come close to what the chart says....
