Will 295s fit
Old Jan 7, 2020 | 05:04 PM
TXZ28LS1's Avatar
Default Will 295s fit
Getting ready to place an order for 18" Chrome C5 DD..I want to get 18x10.5 in the rear. As much as i want to slap a 305 in the rear, i am looking at 295s.
Will 295s fit perfect with no rubbing or having to do bfh?
Thanks
Old Jan 7, 2020 | 07:48 PM
huggerls1's Avatar
ive got 295s on 19s in the rear, c6 corvette wheel spacing so I needed to use a spacer. They fit fine, do not rub or hit anywhere. I am also lowered like 1.5 below stock ride height.
Old Jan 7, 2020 | 08:19 PM
joeformula's Avatar
I have 305’s on my 18x11’s with no rubbing. I’m actually going to be selling them to get 315’s.
Old Jan 7, 2020 | 10:27 PM
TXZ28LS1's Avatar
Thanks guys for the replies.
I did a search and it seemed seemed 295s fit. Dont know the offset thats needed. Ill be doing BMR springs and panhard as well.
Old Jan 8, 2020 | 11:00 AM
hokeplaya05's Avatar
depending on wheel offset you should be good, will be tougher if lowered. i have 295's on all 4 corners of my car and had to roll the rear fenders and do a little BFH but I'm lowered over 2" on coilovers
my wheels are 18x10.5 +50 and sit just about flush with the 1/4
Old Jan 8, 2020 | 11:24 AM
TXZ28LS1's Avatar
Thanks hoke.. yeah im still at stock height and will be ordering bmr springs. Just hoping they clear. I think a 305 might be tougher fit.
Old Jan 8, 2020 | 11:34 AM
Chris Paveglio's Avatar
315s fit fine in the rear, but you have to roll the inner fender. You've got a TA so even a bit easier than a Camaro, if the rumors are true. I get a little rub in the inside but only when I race (autocross) pulling big G's.
Old Jan 8, 2020 | 12:22 PM
TXZ28LS1's Avatar
Thanks Chris.. well im trying to find out about 295s if they fit no problems at all lowered.
Old Jan 9, 2020 | 11:17 AM
if nothing else you'll probably want to roll the rear fenders since you'll be lowering the car for peace of mind, don't want your brand new tires getting cut up by the fender lip
Old Jan 11, 2020 | 04:41 PM
2JAWZ's Avatar
From my experience 295's should fit fine without modification unless you slammin it😎
Old Jan 16, 2020 | 09:37 PM
TXZ28LS1's Avatar
Ended up placing an order for the 18x9.5 C5 DD. I got 275/35 for the front, and 285/35 for the rear.
Hopefully i dont regret not going 10.5 in the rear with 295. I wanted to play it safe and knowing it will fit.
Old Jan 17, 2020 | 06:06 PM
No Juice's Avatar
Here you go, see post #21 These are mine and no rubbing except in the front inner fender liner
https://ls1tech.com/forums/wheels-ti...s-18x10-s.html
Old Jan 28, 2020 | 10:24 PM
bad_408_vert's Avatar
When I lowered on 285/35/17s I saw that having an adjustable pHB saved me from rubbing.
On 1.25” bmr low springs with Konis
