F14's - 295/35's on 18x10's
Here are some test photos. I'll post more once mounted. This will be a square set up. Tires are Toyo T1 Sports.
These are a lot wider than the 295's I had on my 9.5's.
Thoughts?
****EDIT ------ Finally got them mounted and cleaned for some photos.......see posts below
Thoughts?
Are you running 18x10 for all 4? what were the specs on the wheels? any issues with that size? I'm about to buy a set of 18x10 F14 and have been trying to figure out specs for the wheel
https://ls1tech.com/forums/wheels-ti...14-wheels.html
Street driving you won't see any issues.
What is a bad combo exactly??
I use a weaker pump than stock and use nothing smaller than a 295 on the front, typically 315s though, but I only use 25.6" or smaller diameter. Why I commented above it will likely rip the inner fender up if not out in a hard corner. 315s and 25.6" tall, and I am not as low as most lowering springs, as I have coil overs. https://1drv.ms/i/s!AiGN7xzHDq5vhEhVSDvrHZLNmmCB
Rampant - where is it going to hit? or as you said rip it out?
I've had a 26" tall tire up front prior to this and it never made contact, granted it was 1" narrower.
Front and rear of the opening about 4-6" in. Happens when near full lock when you have good grip and pushing it. I had 550lb springs and a 36mm front sway bar. This happened with both a 315/35 17 on a 10.5" rim, as well as 255/45/ 17 I had at one point as a staggered set up. If you wear through the inner fender the tire can grab it and pull it out. Almost nothing holding them in.
Let it be known that just because something "fits" and does not hit something sitting statically in your driveway and or sitting static at full turn does not mean it won't be an issue.
I have seen my 315/30/18 tires deflect up to 1/2" when in hard cornering. When checking clearances I shoot for 3/4" or more.
For street driving...you may never see issues. Some claim 335's "fit" in the back with minimal mods...take a turn fast and you will be real sorry lol.
With that soft of a spring you will stuff that tire in the fender. I had 550/150 and 315's and I would rub the fender. With a 26.25" fender to ground front ride height and 850/250 springs I can still slightly kiss the tire to fender. Next up is trying 900+/300+ springs. ORRRR have the shock compression re-valved.
I have more camber now. Around -2.6. Above was maybe -1.5 with my Global West uppers.
