Mess Up Abs????
Old Feb 15, 2005 | 09:54 PM
00ls1's Avatar
Possible Scammer - Buyer Beware - Issues Unresolved
Default Mess Up Abs????
i am wantin to put Y2K vette wheels on my T/A. will 18/9.5 mess up my ABS??
i was told by one guy that they would but i wanted to post here to see what ya'll's answer would be
Old Feb 15, 2005 | 11:30 PM
Walker's Avatar
HEy Doug, from what I heard, you are wanting to use the 17"x8.5" wheels up front, & the 18"x9.5" wheels out back. You'd end up using tires that aren't the same diameter front to rear. Unless I'm mistaken, that will cause problems with the ABS.
I'm sure an f-body owner here will know for sure.
Old Feb 15, 2005 | 11:57 PM
00ls1's Avatar
I'm sure an f-body here owner will know for sure.
hopefully they will. but on a more important note, how about a ride in the GTO
Old Feb 16, 2005 | 12:12 AM
Walker's Avatar
Old Feb 16, 2005 | 12:50 AM
jimmyblue's Avatar
Moderator
From what I've seen, F-bodies start having ABS problems
at right about 10% tire circumference difference. Below
that I haven't seen any beefs; above it, a couple.
Old Feb 16, 2005 | 01:46 AM
SJM Manufacturing Inc's Avatar
Jimmy how's it going?
Actually, around 3.75% difference abs will start to complain. At 10% it's a guarantee.
Steve
Old Feb 16, 2005 | 12:19 PM
BriancWS6's Avatar
With the 275/40/17 in front and 26/10.50/16 MT bigends out back I got some weird pedal feedback at the track on my pewter car.
Old Feb 16, 2005 | 05:13 PM
00ls1's Avatar
then what size 18 inch tire would have the same circumfrence as my 275/40/17???
doug
Old Feb 16, 2005 | 07:38 PM
Walker's Avatar
A 275/35-18 or 285/35-18 is very close & should be ok.
Old Feb 16, 2005 | 11:24 PM
jonnyc's Avatar
i had 275/40/18 on the back and 275/35 18 on front for about three years and never had any problem.the rears were probably 1/2 inch taller.
Old Feb 16, 2005 | 11:55 PM
00ls1's Avatar
ya but i wil have 17'son the front.
so if the tires = out to the same circumfrance the ABS will work fine?
Old Feb 17, 2005 | 12:25 AM
jonnyc's Avatar
if you run 17 and 18,you'll probably want to go with what the vettes use.295/35/18 rear and 265or275/40/17 front.you should be able to fit a 295 on a 9.5 wheel.i use to run 285s on a 17x9 wheel.
Old Feb 19, 2005 | 07:55 AM
Gregg_98TA's Avatar
The actual value is 6% which will set a wheel speed sensor Lamda fault. In order to avoid this fault you should stay below a 3% difference in rolling circumference. Staying as close to the stock rolling diameter as possible is best for performance.
