pics of your 7.5" back spacing?
Old Mar 31, 2005 | 07:47 PM
M6HuggerSS's Avatar
Question pics of your 7.5" back spacing?
i was thinking of getting some welds 15X10 15X3.5 with 7.5" BS...
please post your pics so i can see how they look!
and how much is needed to make them fit?
also what tires would fit well and drive well on the street, id like to fun BFG DR in the rear...
any help would be great! thanks.
Old Apr 1, 2005 | 08:33 PM
M6HuggerSS's Avatar
ttt........
Old Apr 1, 2005 | 08:50 PM
GM Muscle's Avatar
I don't have a pics of them on the car yet but this pic may help you see what kind of lip they have and give you an idea of how they might look. Tires are 275/50/15s. You should only have to grind the calipers in the rear to get them to fit with this sized tire. In the front you can run a 5/16" spacer and not have to do any grinding, you'll want to pick up some longer studs if you do that. There is a thread floating around somewhere with pics of how much grinding you'll have to do in the rear.
Old Apr 15, 2005 | 08:29 AM
m6z's Avatar
m6z
do you know if you have to run the spacers in the front. Or can you just grind the **** out of the calipers.
Old Apr 15, 2005 | 09:28 AM
Derek98z's Avatar
You can either run spacers in the front and grind a little, or grind a lot and run no spacers. Pics in sig without spacers. Go to my cardomain for more pics
Old Apr 15, 2005 | 01:05 PM
69TA's Avatar
I have a pair of already modded rear calipers for sale. If you want to spare your original ones. PM me if you want em.
thanks,
Kevin
Old Apr 15, 2005 | 05:08 PM
Hardtop00SS's Avatar
I have pics of 15x10's and 15x3.5 on my SS in my link in the sig...
Old Apr 16, 2005 | 04:59 PM
GM Muscle's Avatar
Just stuck mine on today. Everything clears fine with the M/T 275/50/15s.
Old Apr 16, 2005 | 06:20 PM
Matt D's Avatar
Retired Street Racer
i have 15x10 weld prostars with 275/50/15 MT DR's on back, and 15x3.5 up front with kumho radials. for both the front and rear, i ground and ran a spacer. on the backs, i had to remove the bumpstops because the tires were too wide and hit. here are some pics:
