OK to remove the bumpstop?
Old Jun 11, 2005 | 08:09 PM
9silverbird8's Avatar
Default OK to remove the bumpstop?
Just as it says. Anyone think its a terribly bad idea? Would definitely allow for more room for the suspension to work.
Old Jun 11, 2005 | 08:22 PM
JohnnieMo's Avatar
If you remove the bumpstops - ask yourself this... What will the suspension hit next??? I'm betting its a lot more expensive that a piece of rubber.
The bumpstops are there for a reason.
Old Jun 11, 2005 | 10:35 PM
WordSS's Avatar
Removed mine, I'm fine
Old Jun 12, 2005 | 02:00 AM
I went ahead and took 'em off. Seems fine.
Old Jun 12, 2005 | 11:36 AM
UnderPSI's Avatar
No problem here, I am in Wisconsin too roads don't get much worse than here.
Old Jun 12, 2005 | 02:06 PM
TS6's Avatar
TS6
I took them and their mounts off with a plasma cutter. Fine so far....
Old Jun 12, 2005 | 09:05 PM
tim99ws6's Avatar
Took mine off too. no problems here
Old Jun 13, 2005 | 07:36 AM
Pewter_LS1's Avatar
I heard you can shave them too give yourself a little more room..if that makes you feel more comfortable...
Old Jun 13, 2005 | 12:48 PM
777's Avatar
777
I would shave before I removed.
Old Jun 13, 2005 | 04:00 PM
Xsta Z 28's Avatar
I'd never remove the bumpstop. You destroy your shocks w/o em . . .
Old Jun 13, 2005 | 04:12 PM
Fade2blk500's Avatar
I'd say shave them down about half way.
Old Jun 15, 2005 | 11:17 AM
ArcticZ28's Avatar
Please let me take this out of context.
Old Jun 15, 2005 | 06:07 PM
Old Jun 15, 2005 | 06:14 PM
Mike K.'s Avatar
took mine out no problems here either, unless you plan on going mudding or rock climbing you probably wont see an issue, plus most of us that remove the bumpstop have stiffer springs as well so this helps.
Old Jun 15, 2005 | 07:16 PM
Charging TA's Avatar
I need to get a new one... well my is falling off the mounting surface, and I did not want to pull it completely off... Anyone know where I can get new ones?
Old Jun 25, 2005 | 11:22 AM
JasonWW's Avatar
If you are at stock height, you shouldn't need the bumpstops.
Here are 2 of my threads that have a bunch of info on this subject.
Stock Shock and Suspension Travel Specs
Bumpstop Spring Rates Inside
Here's a qoute from the above pages that focus on the point in hand.
Unlike what is commonly believed, the rear axle will contact the exhaust going over the top before there is metal to metal contact where the bumpstops were. It will also hit it before the shocks will bottom out. (Based on both sides moving together, Cornering is a different story. See Part 3)
So the stock shock travel was 7 1/4". I never noticed my car bottoming out on the metal bumpstop tabs like everyone thought it would. Now it may be different under a cornering load, check Part 3. The shock bottoms out (3/4") before it can make metal to metal contact on the bumpstop tabs and will hit the exhaust pipe 1/4 inch before that. Very interesting stuff (to me at least).
I want about 1/2 inch of bumpstop compression before axle contacts the metal exhaust pipe. This way I get max suspension travel.
