Bumpstop Spring Rates Inside
1. the medium 40mm foam one from my front Koni SA shocks #70.34.54.000.0
3. the Ground Control front from their adjustable perch kit
2. the front factory orange unit (from 99 T/A)
4. the rear factory yellow tapered unit (from 99 T/A)
5. the longer 55mm version of the first Koni #70.34.53.000.0
Keep in mind that you have to plot the pressure over the distance traveled. The length makes a big difference, too. You'll notice I didn't measure the GC past 3/4" while the (shorter) Koni, I measured to 1". The reason is because the GC was much shorter than the (shorter) Koni and the pressure was starting to ramp up very quickly.
First up is the (shorter) Koni which measured 1 1/2" long (40mm).
How much squished - pounds of pressure
1/8 55
1/4 75
3/8 90
1/2 105
5/8 110
3/4 150
7/8 200
1" 300
Next is the Ground Control unit. It measured 1 1/16" long.
1/8 50
1/4 70
3/8 95
1/2 140
5/8 220
3/4 290
Next was the factory front piece which was right at 1 1/8" long
1/8 210 pounds!
1/4 290
Whoa! I knew the stock piece was a lot stiffer but this surprised me. So at 1/8 inch of compression it is about 4 times stiffer and it doesn't look progressive at all. (I actually broke the scale and had to go buy another one. I retested all the pieces again with the new scale.)
Next is the factory rear which is 2 5/8" tall
1/8 45
1/4 65
3/8 95
1/2 125
5/8 150
3/4 200
7/8 260
This one surprised me, too. I thought it would be much stiffer than this. Everyone seems to mention how firm they feel and that they can snap the rear loose in a fast corner. I wonder if it's the first 1/8" or so going from 0 to 45lbs that is too sudden or maybe it's that it ramps up too quickly in the middle area. The only why I can think to lower the rates would be to drill some holes through the side. Where, what size and how many will make it softer in the areas you want. I imagine there is a science involved in figuring that out, also.
Last is the longer Koni bumpstop, I recently ordered, which is 2 3/8" tall (55mm).
1/8 30
1/4 45
3/8 60
1/2 70
5/8 85
3/4 100
7/8 110
1" 145
1 1/8 195
1 1/4 260
This unit is the same as the Koni bumpstop I tested as #1, just a little longer. The increased length makes it more progressive and quite a bit softer initially. If I where to chop it down to match the height of the shorter Koni I'm sure it would match it's rates. It feels like the same material and softness, just shorter.
If I had the time I would plot out the curves in a graph, but due to not having a web host, I wouldn't be able to post it anyway. The main thing here is to look at the slope and how the pressure ramps up.
Even if most have no use for this info, I hope someone will find it interesting and perhaps usefull.
Jason
Was recently able to get some pics hosted. Enjoy.
Ground Control also has 4 aftermarket bumpstops that can be bought. I recieved a set from Jon Aadland. They are the "soft, progressive 10-14mm shock" ones. One was full height and the other was one that Jon had cut down. I measured them both and here are the results.
The longer one is 2 1/8" tall
1/8 25
1/4 35
3/8 45
1/2 60
5/8 70
3/4 85
7/8 110
1" 135
1 1/8 160
1 1/4 210
1 3/8 300
The shorter one is 1 5/8" tall.
1/8 20
1/4 35
3/8 45
1/2 55
5/8 75
3/4 100
7/8 140
1" 200
1 1/8 300
Link to Ride Height and Suspension Travel Specs
crosslink to FFRAX
Thanks Jason!
-Mike
Anyway, at stock ride height I found I could get away without bumpstops, but once you lower the ride height, you will definately need them. The big problem with the stock rears is that they are too stiff and limit usefull suspension travel. I would recommend cutting about 1/2" in length off of them and then cutting a taper back on it so that it is more progressive in rate. 1/2" of extra travel can make a big difference.
On my car, I measured out how much travel I had and then fitted the best bumpstop I had onto my shock body. I'm running the Koni SA rear shocks and this is what I came up with on my car.
Once I lowered the rear to about 26 1/4" or 26 1/2" (I can't remember right now) there is was only about 1/2" between the bumpstop and the shock body, but that's OK. I'm running a stock spring modded for 170lb linear rate and have the Koni shocks adjusted where I want them. Even though the Koni 55mm bumpstop gets used all the time, it's so smooth and progressive I really can't feel it. The rearend just soaks up the bumps with ease and that's the main goal.
With at least the rear bumpstops, they do get used, but more often than not, they don't dissolve from use but rather the metal they are bonded to rusts out and then the bumper seperates from the mount because of the rust.
The only thing I can really add here is that the ones that are MCU (foam, cell appearance, not solid like poly bushings) use a material that is very linear in response until the cells are completely compressed, then the stiffness shoots up.
If you are trying to do tuning then the MCU is actually very machineable. You can cut or drill on it to obtain the rates you want, and it is not prone to fatigue cracking like rubber or poly, so long as you keep it working only in compression.
On those rear one I've seen falling apart, I'm not sure of actual cause but they were still intact at the mounting point, but the tapered end was all beat up like it had taken multiple poundings over a long time.
The progressive nature also seems to be mainly in the shaping. More of a taper will make it more progressive. I was thinking a few holes through the side of a stock rear bumpstop would soften it up a little and make things better. It's good to know that drilling holes in it won't hurt the material.
One other thing. If you still have the metal SLP spacers on your rear bumpstops, it's safe to remove them. They seem to be utterly useless as well as rob you of usefull suspension travel.
For anyone doubting that the rear bump stops get used, take a look at the pads that are welded on the top of the axle for them to contact, I’ve never seen a car that they’re not shiny on.
That being said, does anyone know of any MCU style bump stops that are single stud mounted? I'm not even sure that I care what shape, since it's easy enough to carve them to the shape (and rate) that you need.
My other question is about the rears. Do the Koni SA shocks NOT come with the 55mm bumpstops? Did this guy buy them and add them? And so the 55mm stops on the shock body would allow me to ditch the factory style ones that hit the rear axles? I have an SS with the spacer and the hard rubber. I was going to get new Z28 bumpstops but not if I can buy Koni SA's with them or add them to my new Koni shocks. I have the fronts already. I've been meaning to get the rears anyway.
It depends on the shock, but usually yes.
Yes, I did. I was running 315's and they would rub, so I cut the bumpstops off completely, then set up the new bumpstops on the rear shocks so as to gain a little more travel.
If your not running 315's and can keep the stock bumpstop location, then why not do that? Are you trying to increase compression travel?
When you cut a spring, it's rate goes up. The rate increase on the rear is actually good (approximately 20lb. per coil increase), but the fronts are still going to be too soft.
Remove those rear spacers, then get the rear shocks. That should solve most of your ride quality issues. Set the rear shocks rebound to full soft. It won't be sloppy. (There are not 8 settings. I show this in my Koni adjusting thread)
Your current bumpstops are a rubber like material. When they compress they want to push the axle back quickly. This leads to a bouncy ride. The regular bumpstops are made from cellular polyurethane. They compress easily, but don't spring back super fast. This helps get rid of the bouncing.
If you have room for more rear suspension travel without over compressing the shocks, you can cut down the new bumpstops some (maybe 3/4"). Just make sure you keep a tapered shape.
There are a lot of other things that effect ride quality as well. What rear tires do you have and at what air pressure do you keep them?
