Time to get mad !!!!!
Old Jun 18, 2005 | 05:46 PM
smokeum99ta's Avatar
Default Time to get mad !!!!!
This is probably a commoning asked question. I've been through the stickies and dont have the patience to try and figure out something that you guys already know. I'm buying some weld draglights rims and tires for the rear of my 99 trans am. I'm gonna get 15" tall rim and would like to know how wide I can go and how much offset is needed. I currently use my stock rims with 28"x11.5" mickey et's and would like something similar in size. And also I have extended wheel studs that are 1/2" longer than stock and will the regular 12 x 1.5 SS/T lug nuts work with that or will they bottom out before it gets tight on the new rims?
Old Jun 20, 2005 | 05:26 PM
Alright lets make this simple ! What back spacing on 15x10 rim do you use ? And is there anything else I need to know (spacer or grinding) to get them on there .I'll figure out if the lug nuts work or not.
Old Jun 20, 2005 | 05:32 PM
hpjunky98's Avatar
you might have to grind the calipers in the rear
Old Jun 20, 2005 | 05:34 PM
Tally TransAm's Avatar
7.5" backspace and if your using welds (or anything other than bogarts) youll have to grind the nuts off your rear calipers
Old Jun 20, 2005 | 08:09 PM
Thank you Tally TransAm for the help. Which nuts are you talking about?Or are you being funny?
Old Jun 20, 2005 | 08:11 PM
grind the nuts off, grind the **** outta, grind the fuggen **** outta it
get it
Old Jun 20, 2005 | 08:37 PM
get it
Got it!!!! Thanks wise ***
Old Jun 20, 2005 | 08:56 PM
welcome ********
Old Jun 21, 2005 | 05:45 AM
DopeFedZ's Avatar
You guys are silly.
