Drag Radials for 18*10.5 57mm offset Z06's
Old 08-03-2005, 02:45 PM
HOSS99's Avatar
Default Drag Radials for 18*10.5 57mm offset Z06's
Sorry if I missed this, but ......
Will a 18*10.5 57mm offset Z06 replica with a Nitto DR 305/35 zr18 fit on a 99' Camaro SS? I'm afraid it may be too tall, so I may just go with 18*9.5 with the Nitto DR 285/35 zr 18 or maybe the BFG DR 295/35 r18 or 315/30 r18 on the 10.5 rim? Thanks for the help?
Nitto DR, & BFG DR Chart are thumbnailed.
Attached Thumbnails Drag Radials for 18*10.5 57mm offset Z06's-nitto-dr-chart.jpg   Drag Radials for 18*10.5 57mm offset Z06's-bfg-dr-chart-cropped.jpg
Old 08-03-2005, 07:18 PM
Tally TransAm's Avatar
the 305/35 will fit, it will cause a slight loss in effective gear ratio from the height, but you can make up for it with gear
Old 08-04-2005, 12:46 AM
ls1muscle's Avatar
ive got 305-35-18 on mine, they look great
Old 08-04-2005, 07:02 AM
HOSS99's Avatar
Do you have any pic's?
Old 08-04-2005, 07:11 AM
blaSSt's Avatar
I'm running 305/35/18 on my car. Lowered 2". (Not the best pic)
Old 08-04-2005, 07:18 AM
HOSS99's Avatar
Any rubbing or fitmit problems?
Old 08-04-2005, 08:57 AM
blaSSt's Avatar
BFH mod and 1/8" wheel spacers and the inside clears well. The fender lip has not been rolled and the tires just miss.
Old 08-14-2005, 01:00 PM
sercastiK's Avatar
did you run a longer wheel stud? looks great
J
Old 08-14-2005, 07:03 PM
blaSSt's Avatar
Yes I'm running ARP studs.
However, if you car is stock the studs aren't really necessary. I broke several studs after a nite of launches on ET Streets.
Old 08-14-2005, 09:55 PM
sercastiK's Avatar
ArP has 1.5 and 2.5 inch ones, which one do i want?
J
Old 08-15-2005, 06:29 AM
blaSSt's Avatar
I bought the long ones and trimmed them to length.
