96 WS-6 with Z-06 wheels w/ Nitto 305/35/ZR18s on the rear
Here is the first mods I have done to the car:
HAL coilovers 12-way adj. up front 325lb springs
HAL 12-way adj. in rear, BMR springs
Spohn adj. pan hard bar
BMR subframe connectors
Total spent for suspension: $1247.05
Replica 18 X 9.5 Z-06 wheels up front w/ 275/35/ZR18 NITTO NT555s
Replica 18 X 10.5 Z-06 wheels in back w/ 305/35/ZR18 NITTO 555RIIs
Total spent for wheels: $1908.00
Tell me what you all think. The car DOES NOT RUB AT ALL, and that is hitting corners at 75-85 mph with no tire slippage! And yes, I had to remove the bump stops, and plasma cut in inner fenders a bit, and of course do some major BFHing to the wheel wells, and roll the lip a bit. But in the end it was all worth it. People can not believe how well the car handles. No I just need to install the Vortech S-trim kit with aftercooler that I have sitting here, and do the headers and custom exhaust w/ no cats. I will be using LT1edit for tuning.
I am building the car towards that direction. Just not sure about the blower honestly. I am leaning towards a turbo setup. I need to make the cage and do some sort of custom strut tower brace this fall for it. It should be all done by spring.
Originally Posted by Chaotic Firebird
[Homer]Gaaaaaaahhhhhh[/Homer]
Yes, I noticed that also, I haven't driven the car for a few days, and I did take some air out. Thanks!
Oh, the drag radials are a different tire. NT555s are extreme performance, the 555RII are more of a road race tire, similar to drag radials as far as softness.
I just looked at my invoice and it does have a 56 at the end of the model number, so I presume you are correct. Thanks for clarifing that for us.
You have the tires on the wrong end.
555R is the Drag Radial and should be on the rear since they have a nice soft sidewall, which is not good for the front since the tire will roll over on itself easier.
555RII should be on the front or on all 4 corners. They have a really really stiff sidewall and are designed for road race/auto-x and stick like crazy when they are warmed up.
Yeah, I just noticed I typed that wrong, my appologies to the above person I corrected. Thanks for pointing that out. I have NT555 Extreme Performance on the front 555RIIs on the rear.
