rolled fender pics
Old Sep 7, 2005 | 11:35 PM
kissell_13's Avatar
Default rolled fender pics
could someone post some before/after pics of rolled fenders. i don't think i've seen them before. thanks
Old Sep 8, 2005 | 07:19 AM
Arachnotron's Avatar
Here is an after picture.
Old Sep 8, 2005 | 11:02 AM
Bad Blu Formula's Avatar
So doing this doesn't affect the paint at all?
Old Sep 8, 2005 | 05:00 PM
Mattism78's Avatar
Not if done correctly
Old Sep 9, 2005 | 07:47 PM
tristatez28lt1's Avatar
how do you do it correctly?!
Old Sep 9, 2005 | 10:31 PM
Slammed-am's Avatar
Hey, guys! I'm really interested too because I have some huge 315 GS-D3's on my Fikse's that need to be crammed in! Help us out, ls1-guys!
Old Sep 10, 2005 | 05:59 AM
Diesel's Avatar
In order to do this without damaging the paint, you would probably want to etch a line for along the leading edge where you are rolling the fender. You also want to make sure to use the proper tool (I think Eastwood has it) to roll the fender safely. If not, you can always take your chances with a wooden bat.
The Paint can very easily chip off of the area that's being rolled, so make sure to etch well, and take your time so as not to make any creases in the quarter panel.
Old Sep 10, 2005 | 05:20 PM
Hardtop00SS's Avatar
what method did you use to roll the fender lips??
Old Sep 10, 2005 | 09:46 PM
That's not my car, but they used an eastwood fender roller.
Old Sep 11, 2005 | 12:20 PM
Yeah, that tool looks expensive. Especially since you'll probably only use it once.
Old Sep 12, 2005 | 07:39 PM
slimcracka's Avatar
yeah is there any where locally that you can rent a tool like that i really like how it work and the finished product.. awsome job...
Old Sep 12, 2005 | 10:00 PM
KelloggSS's Avatar
What is the proper tool to etch where you want the bend?
Old Sep 13, 2005 | 08:29 AM
01 Red WS6's Avatar
I heated the paint with a heat gun and I didn't etch a line. I didn't have the paint crack or anything else happen
Old Sep 13, 2005 | 01:03 PM
99zee's Avatar
There are a couple of guys on here that rent the tool. Can't remember who they are off the top of my head. That would be the way to do it.
Old Sep 13, 2005 | 01:22 PM
Fulton 1's Avatar
Those pics above are of my SS. Here are a couple more to illustrate the before/after differences. For reference, these pics show 18x10.5 rear wheels with an effective 48mm offset (53mm wheel + 5 mm spacer) and Michelin 295/35/18 PS2's. Car is lowered about 1.75".
Before:
After:
As Red WS6 noted above, a heat gun is required to heat the paint and prevent cracking. Just heat the corner of the lip to around 160-190F or there will be a very real risk that the paint will crack. Scribing a line in the paint on the lip will probably work as well and I have heard of people doing that, but I haven't used that technique myself so I couldn't comment on how well it works.
I have a fender roller that I rent out from time to time as do a couple of other folks on here. Since the tool is expensive to buy renting is a good good idea. Best thing to do is check locally for a rental since shipping back and forth gets pretty expensive.
Old Sep 13, 2005 | 09:15 PM
Slammed-am's Avatar
Thanks for the pics! Very helpful. So basically, "rolling" the fender is just pushing that little lip back so it won't contact the tire?
Old Sep 13, 2005 | 11:38 PM
01 Red WS6's Avatar
Yep thats right it's real easy to do
Old Sep 13, 2005 | 11:46 PM
kissell_13's Avatar
my car is being repainted...so i'll prolly just try it will some metal working tools my uncle has then let him make it look nice and paint it thanks for the pics.
Old Sep 25, 2005 | 12:46 AM
badride5's Avatar
AN old school trick is use a wood baseball bat and pry using the tire. Best if you heat the metal so you don't get wavs but i done my 76 Camaro with a Big Ol Rubber mallet after taking the tire off. I just took my time and it did not mess the paint up.
