17x11 ZR 1 rim offset questions
![Post](https://ls1tech.com/forums/images/icons/icon1.gif)
+36 mm or +50 mm? Which offset would give a more agressive look on a 315 in the rear? The larger the offset the wider the look? Or is it the other way around
. My car is pretty much stock so I wouldnt need stronger studs correct? Would I need spacers?. Thanks - TP
![Driving](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_driving3.gif)
