hub centering rings for evos?
Old Jan 28, 2006 | 10:49 PM
  #41
qwikz28's Avatar
Originally Posted by TNTramair
yes...this is what you need!! if you have any play when you put your wheels on, than it will vibrate. hub centering ring placed the wheel perfectly even all around the center hub..vibration gone.
this is where i got mine from. http://aolsearch.aol.com/aol/redir?s...ings%3C%2Fb%3E
just measure the diameter of the hub on your rim and the stock diameter for our cars is 70.3mm. hope this helps..later.
i would check with AR to be 100% precise.
Old Jan 28, 2006 | 10:51 PM
  #42
qwikz28's Avatar
Originally Posted by slayer6x6
So how much you want for the HPR5s?
i payed 2200 for them but i would probably sell them for 1700. tires only have about 5k on them. PM me if you wanna come take a look at them. how far are you from NJ?
Old Feb 14, 2006 | 10:56 PM
  #43
98a4z28-410rwhp's Avatar
do these just slip on
Old Feb 15, 2006 | 06:42 AM
  #44
TNTramair's Avatar
yes..slide them over the hub..than put your wheel on...or vice versa.
Old Feb 15, 2006 | 11:37 PM
  #45
Gary Henrion's Avatar
Talking HP Evo vibration problem
I have a set of 19 evo's on my 02 ws6, It's the 5 lug nut's that center the wheel on the hub, not the hub itself. Be sure you have the proper lug nuts, they sent me the wrong nuts and I almost fucked them up installing them. I ended up using my stock GM nuts/ locks and used my stock black lug nut covers (the plastic had to be ground down very carfully) to fit in the lug hole.
It looks oem. Also make sure to remove the two factory brake rotor star washers, because they can cause uneven wheel runout/vibration.
also torque the nuts in a crisscross star pattern up the recommended torque.
just my two cents
P.S. injection is nice, but I'd rather be blown
Old Feb 16, 2006 | 08:08 PM
  #46
Dans2000SS's Avatar
From what I understand, the studs aren't strong enough to support the weight of the car. The wheel needs to fit the hub.
Old Feb 17, 2006 | 06:48 AM
  #47
TNTramair's Avatar
they'll support it, but it'll never truely be centered with just lug nuts...no matter what type of lug nuts they are. if there is any play between the vehicle hub and the wheel hub, it will never be perfectly centered. you should have the centering rings.
not to mention, not having the rings, you run the risk of chewing up the inside of the wheel and the stud holes as well b/c of the slight movement that it encounters. i personally never run a wheel without a ring...unless they are a perfect fit like the stock wheels.
Old Feb 17, 2006 | 07:01 AM
  #48
Dans2000SS's Avatar
I agree. I have rings on my Budnik hammers.
