hub centering rings for evos?
Old Nov 11, 2005 | 01:43 PM
JCurtin's Avatar
Default hub centering rings for evos?
I did a search cant find what i need to know. I have a set of hp evos waiting for me when I get back. Who all is running the hub centering rings? Where can I get them, and which ones do I need? Thanks guys.
Old Nov 12, 2005 | 09:07 AM
TNTramair's Avatar
i dont think you need em...they bolt right up from what i understand..i could be wrong though. if i am, i need to know cause ill need em for mine as well.
Old Nov 12, 2005 | 03:33 PM
FH212's Avatar
I got mine from a non sponsor.Same place you got yours jcutin.they are just plastic steped rings.But I have no idea how they go on.I still have to buy tires.
Old Nov 12, 2005 | 07:22 PM
JCurtin's Avatar
dont feel bad, i havent even seen mine in person yet! I need tires as well. No hurry for them though. I mean whats the rush, i aint leaving no time soon. I'm going with 285s out back for sure though. i just want to see some pics of them mounted. I got mine from wood and wheels, and he didnt have the rings. What lug nuts are u guys going with?
Old Nov 12, 2005 | 07:30 PM
badass 2002 z28's Avatar
i got em on mine..just for good measure...they're 70.3mm
Old Nov 12, 2005 | 07:37 PM
JCurtin's Avatar
how much were they? And would you email me a pic of your car with them please? I am dying to see them mounted!!
Old Nov 12, 2005 | 08:10 PM
like $12
Old Nov 12, 2005 | 08:40 PM
AW/whiteZ-28's Avatar
I coulda swore our cars are lug centric not hub centric...
Old Nov 13, 2005 | 10:31 AM
Xsta Z 28's Avatar
All GM cars are hub centric.
Old Nov 13, 2005 | 03:58 PM
TNTramair's Avatar
like $12
where did you get those rings from??? i need some aswell i just noticed yesterday when i test fit the rims on the car.
Old Nov 14, 2005 | 12:52 AM
qwikz28's Avatar
if you stiill need help pm me. i think i can help
Old Nov 14, 2005 | 08:21 AM
Z'mnypit's Avatar
I didnt use them on my Evo's. They fit perfectly without any problem. The lugs stay torqued & never seem to come loose.
BTW- for lugs, Im using the gorilla lugs, the have a tool that is used for each lug & it fits nicely in each slot...
Old Nov 14, 2005 | 09:52 AM
qwikz28's Avatar
on my HPR5s there is alot of play and you have to try to center them or they do no center and vibrate the car horribly. this baffles me why some guys do without them and other guys (like me) are having the worst time in the world. i bought the centering rings and the shaking is 95% gone. but that last 5% is still bothering me. i got another idea from a wheel shop that im gonna try out as a last resort but if that doesnt work im gonna sell them and pick up some TT2s and pwdercoat them
Old Nov 14, 2005 | 10:09 AM
Z'mnypit's Avatar
I dont have any vibration. the wheels line up fine. that is odd though.
Old Nov 15, 2005 | 10:02 AM
Dans2000SS's Avatar
Is it safe to say that if the hole in the center of the rim is larger than the hub, then we need to have an adapter ring?
Old Nov 15, 2005 | 10:26 AM
Xsta Z 28's Avatar
Yes sir.
Old Nov 15, 2005 | 10:57 AM
TNTramair's Avatar
the hub diameter on our cars is 70.3mm....i havent been able to measure the hub diameter of the evos yet (lack of tool) but i beleive from what i felt, it should be a 73mm bore. i ordered a new set of lugs and hub centric rings in that size so ill let you guys know if i was correct.
Old Nov 15, 2005 | 02:02 PM
Dans2000SS's Avatar
Yes sir.
Thats how my Budik Hammers came. After I test fit them I called because it didn't seem right but they said it was ok. Can you tell me where I can get rings for the fronts? The rears fit the hub. I had wheels on a different car that didn't fit the hub and they broke some of the studs, so I've been concerned about this even after they said it was ok. I'm glad this topic came up.
Thanks for your help.
Old Nov 15, 2005 | 02:03 PM
qwikz28's Avatar
what size evos? HP told me the 18s have a 73mm bore and the 19s have a 74mm bore
Old Nov 15, 2005 | 02:04 PM
qwikz28's Avatar
btw your car is sexy and not only was it my wallpaper for a while but it was my inspiration for many of my mods. thanks
