Help me pick some wheels
Old Nov 15, 2005 | 03:48 PM
gollum's Avatar
Ws6 wheels and lowered car! Although EVO's look good also.
I think this car looks BAD ***!
Old Nov 15, 2005 | 04:09 PM
blu98ta's Avatar
And know where can I get some keyed lug nuts so these dont get stolen?
Old Nov 15, 2005 | 05:18 PM
gollum's Avatar
GM dealership parts and service desk.
Old Nov 15, 2005 | 05:22 PM
slayer6x6's Avatar
Originally Posted by 98 LS WON
Old Nov 15, 2005 | 08:41 PM
8GTOKLR's Avatar
the 8's are two 255/35
the rears are like 275
Old Nov 16, 2005 | 03:59 PM
blu98ta's Avatar
Anyone know for sure what size tires I can put on the 18x8 and 18x9s?
Old Nov 16, 2005 | 04:14 PM
8GTOKLR's Avatar
Will this size fit
Old Nov 16, 2005 | 04:25 PM
'Trust''s Avatar
To lower it you'll need more than springs, at the bare minimum you need springs and a adjustable pan hard rod, when you lower the car it pushes the wheels out to one side more, causing more wear on the wheel that gets brought under the car more, the adjustable pan-hard will re-center this, so that covers your for looks and wear, but lowering the car causes loss of traction and wheel hop if you stick due to the angle change of the lower control arms, so you'll need LCA relocation brackets to fix that at a minimum, then some after market LCA's if you feel like you need them, your ride quality will suffer greatly w/a lowerd car on stock shocks so some QA1's or HAL's would help but arent nessacary
Old Nov 16, 2005 | 08:04 PM
Cheater's Avatar
this is the post you have been waiting on do draglites/prostars
