cheap tires
Could cheap tires cause this?.... No, but the style or tread pattern of any tire could have a little part, but it should not be noticeable, like your describing. Also, if the belts are broken(aka tire separation) in the tire then it would cause such actions. First have the tires checked for defects, then suspension for out of alignment and any worn out parts. Also I have heard of these actions when the steering box on the older cars have worn parts. Since (I am guessing you have 98+ T/A) you should have rack-n-pinion set and I dont know if worn out parts for that setup would cause the same problems, like the old steering box setups.
Good luck fixing your problem!! Hope this helps
later
hummm......there should not be any problem with running 275/40r17 on all four corner of you T/A. That is what the stock Firehawks and SS come with on all corners. Also I have ran 275/40R17 on my Z28s and I run them right now on my 92 RS, so it is not the size of the tire that is the problem.
far as if the rack-n-pinion is causing the problem, I can't answer that. All I know is on the old cars they had steering gear boxes and when the would get worn out then these kind of actions sometimes took place. But far as the rack-n-pinion, I don't really know if the same thing happens or not.
But I did get to thing about something, I not sure if the Fbodys have it or not.....but on the GMC & Chevrolet Trucks and SUVs (I know the 1995-1999...not sure about any other year) had a magnetic disc thing in the steering wheel, that would go bad. When it would go bad it would kind of jerk the steering wheel, but it would not be all the time. It would be working fine then out of nowhere the steering wheel would jerk or feel like something just gave out in the column. Like I said I don't even know if the Fbody have this or not, but if so this could have some effect.
far as the 315s in the rear this would not cause any problems....the rack-n-pinion is just for the front steering.
for instance, the base z28 comes with 245/50-16 = 25.7" tall. the SS comes with 275/40-17 = 25.7" tall. both are the same exact diameter. one has a one inch taller rim. so, to keep them the same overall height, you shorten the sidewall to achieve this. now, with shorter sidewalls, there's less flex. better cornering is the good thing. more road 'feel' is the bad.
different brands of the same size tire try to make their tire perform to one aspect or the other. yokohama makes a really stiff sidewall. firestone makes their tire have more flex in their sidewall. try to make it more comfortable for the user of the tire.
