Pics of 315's 325's 345's
#62
Originally Posted by tekprodave
Haven't you seen the Pontiac commercial? Wider is better!! LOL!!
Your logic is somewhat flawed because you left out one factor......contact patch. And if I wanted to get max hookage I'm well aware of what a full slick can do. We are looking for max traction on a street tire with a relatively stiff sidewall. In this case the more rubber you have on the road the better.
#63
Originally Posted by ls2 bait
u r only partialy correct. contact patch helps u in cornering. a wider tire is not going to make u hook any better in a straight line.
#67
Originally Posted by GMmexican
hey is that back panel powder coated?????........and did you add the "camaro" inlays to the back ?
I got the inserts from dragonz28 here (muffinbuster on ebay). Actually the pic he uses in his auction is my car.
#68
I went with the 315 BFG's just like Lethal on my LT1. The rims are 17X11 ZR1's with 50mm offset which is perfectly centered. I could barely fit a finger between the tire and the inside wheel well so I did a little banging just as a precaution. There is no way I could fit a 335 without looking ridiculous. I like these a lot. They don't hold first gear but I don't think any tire would. They hold second pretty well and the BFG DR's don't turn to mush on the freeway like the MT DR's. Gotta love the wide "steam rollers".
#73
Originally Posted by 93formto98T/A
here's a shot of my 335s. I'm going to attempt some mini tubs and am going to do 345s next time. I'm going to do a photo shoot sometime this spring or summer. Sorry for the sorry pics.
#74
Thanks, I got the car back and took some more rear shots. I also did a new interior so when I get back after next week I'll put up a post with the ride, the 335s, and new interior and seats.
