4th. gen. wheels on a 3rd. gen. ?
Old Feb 22, 2006 | 07:52 PM
JG98's Avatar
Default 4th. gen. wheels on a 3rd. gen. ?
will 9 1/2 fit on my 3rd. generation camaro ?
Old Feb 22, 2006 | 08:48 PM
JG98's Avatar
ttttttttttt
Old Feb 22, 2006 | 09:06 PM
2001whiteSS6spd's Avatar
i Know you need spacers to put 4th gen wheels on a third gen, I think the backspacing in about an inch different but I'm not for sure.
I think 9 1/2 inch wheels would fit with the correct backspacing.
Old Feb 23, 2006 | 01:09 AM
Sixspeed02TA's Avatar
They will fit with 1.5"(I think) backspacing. Look over on the ThirdGen.org website for that kind of info. They have tons of wheel combinations. I also have a 3rd gen....just cant remember what size adapter I had to get...
Old Feb 23, 2006 | 04:04 AM
JG98's Avatar
thanks.
Old Feb 23, 2006 | 06:45 AM
Strokinit383's Avatar
I had a 2" set of adapters for awhile for third gen camaro with zr1's.
Old Feb 23, 2006 | 01:47 PM
nhra-trans-am's Avatar
Moderator
I'd like to see some pics of that
Old Feb 23, 2006 | 02:11 PM
No pics, sold the car before i ever finished it.
Old Feb 23, 2006 | 02:16 PM
But if you doubt that is the correct size, heres my reasoning. Third gen camaro wheels, at least on the iroc, were a 0 mm offset for the rear and +16 for the fronts. Rear zr1 wheels that are run on camaros (11's) are +50mm. 50mm in inches is 1.969. So basically 2 inches. The fronts are +56mm - +16mm = 40mm, which is about 1.575 inches. So I would run 1.5" spacers on the front. That was my plan but just never got around to purchasing the front ones by the time i sold my car. But if you run the 9.5's all the way around 1.5 would work fine.
Old Feb 23, 2006 | 03:12 PM
LS69TA's Avatar
I sold my Enkei Win wheels ,17x9.5", to a buddy and they fit fine on his 91 RS with 1" adapters. BTW stock 4th gen wheels are either 16x8 or 17x9.
Old Feb 23, 2006 | 03:17 PM
Right, but that was just an example. The offsets will be basically the same as the stock 4th gen wheels. Give or take a little.
Old Feb 23, 2006 | 05:58 PM
spectrez28's Avatar
I am running 2" adapters on the front and 1.5 on the rear with stock gm ss wheels and bfg comp ta 285/40/17 all around.
